@Beast and @namengr inspired me to dig up a kit from my stash and start it, and so here I go!
I’m starting a build of Roden’s 1:35 model of the M43 Ambulance as seen during the Vietnam War.
I started building with the chassis frame. Out of the box this part looks like this:
Because I like to look at my models from the underside, too - I decided to make some alterations here. I have thinned the frame rails and added the flanges out of thin styrene sheet:
I have also hollowed out the parts sticking out to the sides, to make them look more like stamped parts:
One more mod is the rear crossmember - I have converted it a little to take sheet metal rear bumpers - made out of copper - instead of the kit parts (also shown for comparison):
Now I’m working on the axles and springs - it’s important on a model to align everything right - otherwise one of the wheels ends up “floating”…
I still haven’t decided on the paint scheme - if I’m not mistaken I have at least OD (Army), gray (Navy) and blue (Air Force) marking options to chose from - I would appreciate suggestion end reference photos - if you have something please post it here!
Thanks in advance for looking and for all your help - have a nice day!
I used to have a ton more reference pictures but lost them in a computer crash. One thing to watch a bit is the Roden kit seam to sit a little tall on the suspension. Look at the distance between the top of the wheel and the bottom of the fenders on the real trucks. Then the compare it to the kit. I tried to lower it a bit on mine but was still too tall.
I agree on the OD green. If I can I’ll try and get out to the Vets Home a get some pics of the one on display there. I’m pretty sure when we redid it we were able to get some correct paint thru the National Guard unit here. Wayne
I’m sure torn apart here - the popular vote is firmly in the OD camp, but Ginos proposal looks really sharp indeed!
I was fighting with a warp of the fron portion of the frame. First I tried to keep it under some weight to straighten out while the glue (solvent) set - but that didn’t work too well, so I applied some heat and was able to get it straight. So then I have installed the springs and axles, to be able to make sure that the wheels will all be touching the ground when the model is done. Here’s what it looks like now:
Many Roden parts have nasty sink marks on them, but the springs were quite OK - Roden tried to keep the knockout pin marks manageable here. I made the front wheels poseable - let’s see how long they stay that way.
But now I can make sure that all the wheels touch the ground at all the build stages. So now I will try to install the drivetrain. Thanks for looking and have a nice day!
If I remember correctly, don’t install the carb and air cleaner when they show it in the instructions because it makes it hard to fit the front fenders later. Once the fenders are mounted you can add the carb and air cleaner later from the top of the open hood.
No problem, and I assembled the front doors first as they help align everything in the cab area so that it all fits together properly. Otherwise if you build them in the instructions order they may not fit just right later on when you go to install them.
@Beast - thanks a lot for this tip, too. The cab is pretty finicky from what I’ve seen so far. The chassis goes together pretty nicely so far.
And I’ve been working on the frame. I have installed the shocks. The rear mounts had to be built from scratch, the kit parts only work when there is no flange on the frame. Got the front and rear bumpers - the rear ones made from copper sheet, and also the taillights and towing pintle. Finally the transfer case and the drive shafts:
The kit parts have a lot of flash and thick sprue attachments, but once you chisel all the unnecessary plastic away, you get some pretty nice detail underneath - like these tailllights and the tow pintle - one of the nicest I’ve seen recently.
Now I’m working on the motor and the radiator - the mudguards are resting on the radiator.
