Trumpeter 1/35 South African armoured reconnaissance vehicle "Rooikat"
This is partial text from the full article (usually with photos) at https://armorama.com/list/sadf-armoured-reconnaissance-vehicle-rooikat
Amazing looking model! what figures were used for the crew?
Thank you, mcl1974.
This figure is based on a miniart British armored car crew and combines Hornet’s modern British crew heads.
I couldn’t find any detailed material on the equipment of the SADF vehicle crew. I found a photo of the headset using something similar to the British Army.
I love it! You’ve absolutely nailed it! What colors were used?
Thanks ReluctantRenegade ![]()
I used hataka’s SADF color set to paint this model.
https://www.hataka-hobby.com/HTK-AS92-South-African-Army-paint-set
I used it with Tamiya’s acrylic thinner.
I like it,very cool vehicle.
I’m busy with this model as well. Which method did you use for the camo pattern? I started off with masking fluid but the outcome was not as expected. Did you use masking putty?
Excellent built!
