Sanxin metal tracks
It seems the wire for my 1/35 scale M-113 Sanxin metal tracks, has done a Peter Pan on me. Before I order more, does anyone happen to have an idea what the Diameter is?
Warm regards
Grumble
If you have a set of small drill bits you could use them to figure out the
diameter of the hole. Try drill bits until you find a good fit, measure the
drill bit with calipers and then get that size wire.
If you have a variety of different wire sizes you can do the same thing, stick different wires into the hole until you find one that fits.
on the 1 (one) set of Fruilmodel metal tracks i have assembled, I found the supplied brass wire too soft, so I used a micro drill bit to make sure the holes lined up & some steel pins cut to correct length.
