Hi everyone,
I’m strarting to assemble this kit:
by Rodolfo Masti, on Flickr
to make the Shenyang J-15 Flying Shark:
Source: http://navyrecognition.com/
The J-15 Flying Shark is based on the Su-33 design, but it is fitted with indigenous engines, weapons and radar. In many aspects the J-15 is similar to Shenyang J-11 air superiority aircraft that is based around the similar Su-27 airframe.
A quick look inside the box:
First steps …
Will be following your build with interest Rodolfo
Fitting test …
The plane after sanding and a layer of primer …
I tried to make the wing launch rails similar to the original
I strarted to paint the engine areas.
First I applied a coat of chrome …
then I sprayed variuos shades of metallic paint (Dark Aluminium, Titanium Gold, Burnt Metal, Metallic Blue) …
First layer of Gray FS36375 - Mr Color C 308
Some details added and painted …
Plane almost ready for the weathering …
I need your help !!! I made a mistake … I damaged a decal !!!
Could you help me find a way to replace the destroyed decal?
I have tried looking for decals on line but I can’t find anything.
Any suggestions are welcome.
Thanks in advance
Thanks to a friend, who sent me the damaged decal, i was able to complete the plane …
