Available from SOL Model Corp. is its 1/16 scale Sherman turret mounted with the 105mm howitzer.
This is partial text from the full article (usually with photos) at https://armorama.com/news/sol-big-scale-m4-105-sherman-turret
This does look very good indeed, can’t see any foundry marks on it, perhaps they are on the finished item.
Could do with one in 1/35th
Regards
Lou
Yeah it looks excellent.
Archer used to make foundry marks in this scale. I saw them on eBay while searching for 1/35th scale marks myself.
At that scale and price, I find this has too many inexcusable issues:
• Missing cast-in armor reinforcement on the right cheek
• Loader’s hatch should be flush with turret roof when closed
• Pedestal mount for the .50 cal MG appears too tall
• Missing dust cover mounting flange around the main gun mount (present on ALL 105mm turrets)
• Antenna mount is wrong
• Missing commander’s alidade sight (only the mounting bracket is present)
• Missing MG stowage brackets on back of turret
• Lip around the shell ejection port should stand out more
Finally, though this may just be an assembly error, the hinge of the all-round vision commander’s cupola should be more at the 4 o’clock than 3 o’clock position.
