Some airbrush questions
I’m again considering trying my hand at this and came to one conclusion. Instead of trying to adapt it to my shop type Makita I’d be buying a small air brush unit with tank.
A couple questions. First is that from all I have read I would be better off going with the longer learning curve of a dual action brush. Is this true even if the majority of what I would do is not small detail work?
Second question is on paint. I know that there is a lot to get a handle on when starting out and I’d like to eliminate one of the biggest headaches right off the bat, mixing and thinning paint. I want to try practicing with something that is air brush ready such as the Vallego acrylic. Basically I’m trying to eliminate one possible problem (paint mix) compounding ordinary newbie errors.
I can’t comment on the acrylic stuff since I don’t use them much.
About the learning curve and single vs dual action.
I don’t use the dual action feature much, or maybe I do …
I start up with the airflow and slowly add paint into the mix by pulling back on the trigger.
If it gets wet I reduce the paint in the airflow, sometimes cutting off the paint totally and
using the air to “expedite” the drying.
Learning to adjust the needle perfectly can be frustrating, spray, swear, re-adjust, spray, swear, re-adjust. With adual action you use the trigger to adjust the paint flow all the time.
Single action is like driving only using the cruise control, works on long open roads but sucks in city traffic. Dual action can be compared to the gas pedal, constantly adjusting to traffic flow.
Thinning, you’ll get the hang of it after a few attempts. The basic tip is to thin to the consitency of milk (low fat, like 3% fat, which happens to be the regular milk in Sweden …). Milk will cling to the sides of the glass after you have consumed “all” of it, after a minute or so there will be a pool of milk on the bottom. That is the behaviour you are aiming for.
No, you will not paint fine lines from the beginning, even if you try to follow all the advice you get (which may be contradicting sometimes).
Practice, practice and practice some more. Dare to experiment and find your working method.
Use scrap plastic to practice on, some modelers use “paint mules”, bad kits they have given up on but they fill a role as paint targets.
When I started with a cheap dual action and a cheap tankless compressor (put-put-put-put … so fine lines came out as series of dots) I had nice surface coverage under control after 20 minutes or so. Fine lines still has me beaten …
In my experience you’ll still need thin Vallejo Acrylics and nearly everything else for that matter.
I would recommend the first AB be a dual action. It just takes some time and testing before you’re ready to prime and paint.
Go for double action brush, becomes second nature very quickly.
As for paint, use Tamiya, Mr Color, AK Real Colour or any other such and thin with Mr Color Levelling thinner(the magic elixir that it is!) 50:50 paint to thinner, then adjust as you see fit, although I almost always use this ratio. Water based acrylics are a great idea in principal, with no real fumes, but the results are nothing like these lacquer based paint
If you are wanting to airbrush then this is how I would start someone out, and have done actually.
Dual action airbrush, Iwata Revolution or Eclipse
Compressor with tank and moisture trap
Some sort of extraction for the above paints, easily available these days.
The other thing is Mr Surfacer 1500 primer, used with levelling thinner at above ratio, amazing stuff.
Go for it, you will not regret it, it’s just air and paint.
Thanks for helpful advice. I’m not sure by what you mean extraction for paints. Also is it suggested to 50/50 thin paints that are already air brush ready?
Vallejo Model Air is what you are looking for if you don’t want to have to thin your paints. AMMO acrylics are also ready to airbrush from the bottle.
Extractor for fumes, such as this
Although cheaper options are out there.
Tamiya and mr Color, etc need thinning. I hear good things about SMS paints which are airbrush ready, no thinning needed. These types of paint are very forgiving and give great results, but the fumes are toxic and extraction/ventilation are essential.
However Vallejo or Ammo acrylics are a lot less harmful, but are more difficult to get consistent results from.
Really, if you can afford the initial outlay for the airbrush and compressor, then the rest is practice and experimentation. But it is not as difficult as you may imagine, anyone can do it.
That’s the stuff I was talking about.
Dual action really doesn’t take any longer to figure out. Don’t sweat that part. Get a compressor that has a tank with a regulator and a water drain port of some type. Get a water trap that fits closer to the airbrush as the condensation forms in the hose. Don’t cheap out but you do not have to pay a $1000 either. Ask about the equipment here. there are many knowledgeable people here. Talk about where you will be painting. In Florida on a hot rainy afternoon in the garage will be asking for trouble. Arizona could also cause issues. The environment can have an impact.
As an aside, how hard can it be if so many people figured it out? You will be just fine. You won’t be perfect at first but soon you will be painting with the best of them.
Yes the one I am looking at has a small tank and trap and the air brush I am considering also has a small trap that can connect to the brush itself. I’m in northern Illinois and can spray in the house or heated garage . Just something I have always wanted to try ever since first seeing one in it’s jewel box case in a hobby store back in the fifties.
Uh, if that’s the case you better hurry up and get started. I don’t consider myself as having a lot of time left to perfect the airbrush (started in 2012) and I never even saw the fifties, let alone a 50’s hobby store.
Compressors:
There are cheap ones and there are expensive ones.
The major factor, for a given performance range (a compressor to pump the tires of your car will obviously be cheaper than one able to power 2 inch rock drills)
is the noise levels. A silent compressor, comparable to a 15 year old fridge, will cost a lot more than the noisy type that sounds like a hammer drill (97 dB is a lot of noise).
Your choice depends on where you will be using it, can it live in the garage with a long hose to where you are working or will it be at your elbow in a wardrobe converted to hobby room.
Noise sensitive neighbours in the apartment next to you or are the neighbours in their own house 100 feet away?
The absolute requirements for your setup are: tank, pressure controlled power switch, air pressure regulator and moisture trap.
The pressure controlled switch turns the compressor on/off to maintain the pressure in the tank at suitable levels. I think mine swings between 85 and 115 PSI and air brushing is mostly done around 20 PSI (depends on the paint, thinning, the air-brush, the hand that operates it and the goal to be achieved).
The higher pressures can be used for pressure cleaning the model and for blowing away dust. Pressure cleaning: load the air-brush with thinner or water+dishwashing liquid, set the regulator for 5 or 6 PSI and start blasting. Messy but efficient, if thinner is used it can even strip some types of paint. Remember that it can get MESSY.
Depending on your plumbing skills (basic level) the air pressure regulator (sometimes sold as a combo with oil/water trap) and oil/water trap can be added afterwards if the purchased compressor doesn’t have it.
The tank is trickier, they are not sold separately, at least not for the sizes we need. With some deeper plumbing skills it is possible to adapt a fire extinguisher tank (the type using dry powder).
The air pressures we use are in the low to very low range so the dangers of industrial type air supply are not a major concern. Our small compressors usually give up at around 120 psi and the fire extinguishers are built for WAY more than that.
CO2 or NOX containers can also be used, the pressures we use are more or less ambient pressure to those tanks.
If you’re serious, then get a name-brand double-action air brush with a tip/needle size around .35mm. Gravity fed will allow you to use very small volumes of paint (which makes that type more economical for details and small jobs - most scale models). Siphon feed brushes generally offer larger paint reservoirs, but unless you regularly build really large models, it’ll be rare that you’ll need that much capacity. But if you do build large models, siphon feed is an option.
Somewhere in the 1/4 -1/2 oz paint cup size is totally adequate for most scale modeling. Smaller cups need to be filled more often, larger less so. If you’re mixing custom colors, you should mix the color in a larger container (recycled paint jar, etc.) so that refilling your airbrush paint cup doesn’t require mixing new batches of that custom color (to maintain consistency).
Badger and Iwata are probably the most commonly available brands in the US, but any other name-brand brush (Paasche, Grex, Rich-Pen, etc.) will be more or less equal in quality. Differences lie mostly in subtle “human factors” like how the brush fits in your hand, the “feel” of the trigger, etc. I have Badger, Iwata and Rich-Pen brushes in my “toolbox.” I use each one for different types of work, so another consideration is just that - different types of work may require different types of airbrushes. However, the vast majority of my scale model work is done using my Rich-Pen 213C with a .3mm tip. All of the other brushes are usually used for jobs that my Rich-Pen is not suited for.
You will read and hear advice that you can buy a cheap, no-name import airbrush from some discount tool store that will “work as good as any…”. Although there is always a grain of truth in such advice, in general this is a poor option for anyone who is serious about using an airbrush. The fit, finish and quality of these “tora-nocka” airbrushes is all over the place. Occasionally someone gets a really good one, but most often they’re just glitchy, fiddly, and frustrating. The argument that they’re cheap enough to just throw away (i.e. they’re essentially disposable) is a false economy for any serious painter who really cares about his or her craft and art. My personal advice is to stay away from these.
Learn proper double-action airbrush trigger control right off the bat. Better to learn the right way than to try to un-learn bad habits later. Down-Back-Forward-Up. Turn on the air, then the paint. Trun off the paint, then the air. This sequence will GREATLY help with eliminating or mitigating “tip drying” and spatter. With practice (and a reliable source of air) you should learn to keep the trigger depressed and just pull back and push forward to control the paint flow from off to full. PROPER TRIGGER CONTROL IS ESSENTIAL TO GETTING THE MOST AND BEST OUT OF YOUR AIRBRUSH.
Small compressors can be noisy, but if that’s not a problem, you can get away with cheaper ones. “Silent” small compressors tend to be more expensive. In either case, you should always drain the tank after every session to avoid leaving water condensation sitting in it (which promotes rusts and collects other contaminants).
I use a Silent-Air 20A in my studio in our house, but in my large shop, I use an 80 gal Ingersol-Rand. Whatever you use will need BOTH a pressure regulator (with gage) and a filter/moisture trap.
You can use compressed CO2. Commercial compressed gas suppliers (Air-Gas, Prax-Air, etc.) and near you can discuss the options, but there are several standard small tank (cylinder or “bottle”) sizes that are convenient. You might also consider checking with soft-drink vendors who supply restaurants and bars. They have regular route services that re-fill/re-supply compressed CO2 at the customer’s location. (I use Air-Gas for welding gas for my “big” shop.) Once you have a “bottle,” - you’ll pay a deposit the first time - re-fills are done by exchange, empty bottle for a full one. The gas “re-fills” are generally pretty inexpensive once you’ve paid the deposit.
“Thinning” (or most correctly, reducing) paint for spraying is not subject to a “one and done” formula or ratio. With experience you’ll learn the reducing ratios (paint to thinner or reducer) that you use most often, but different application goals and paints require different thinning ratios (along with adjustments for air pressure, paint flow rate, distance from the surface and speed across the surface). Hence, there is no single best thinning ratio that will work for all paints for all jobs in all ambient painting conditions).
I can (and would happily) tell you what I normally use. But unless you’re spraying Tamiya acrylics using Tamiya X-20A + Tamiya Yellow Cap Lacquer Thinner out of a .3 mm tip airbrush, what I do might not work at all for you. For close-in detail work I use a totally different mixing and thinning protocol than I do for general base coating both of which are different than what I might use for free-hand camouflages or painting with stencils.
In the end there is no substitute for experience, so get a good, name-brand quality airbrush. Match that with a reliable and controllable compressed air source and start off using a name-brand line of paints formulated for scale modeling along with that manufacturer’s proprietary thinner / reducer for that particular line of paints. Stick with your choices until you have “cracked the code” and mastered them to squeeze every bit of performance you can get out them. When you reach that stage, you’ll know enough to make informed decisions about changing airbrushes and paints to get what your earlier kit is not giving you (or that you can get all you need or want from what you already have).
They work for surface coverage and maybe a bit more than that but precision jobs are SO much easier with a precision tool.
For someone who regularly needs to spray for general surface coverage, there are two classes of small, vertical format sprayers - large, double action airbrushes and small HVLP guns.
I’d offer up the Iwata TRN 2 as an example of a quality, large double action airbrush, and the Iwata LPH-80 as an example of a small HVP gun. (I have and use both in my large shop.)
For the occasional general surface coverage job, most painters are better off just learning to use aerosol can paint (aka “rattle can”) properly. Cheaper, less mess, faster clean up, etc.
Trying to spray with poor quality equipment is simply not economical and almost always frustrating with poor to unacceptable results. If someone doesn’t spray often enough to justify the expense of good kit (and, really, the difference in cost over even just a few jobs is not that great), then farm the work out or learn to properly “rattle can” it. Decent, name-brand airbrushes are just not that expensive. A REALLY good quality airbrush cost less than a trip to the grocery store or a tank or two of gas for your car or truck.
You will definitely need Airbrush Flow Improver.
It prevents paint clogs, splatter, paint not coming out, and all sorts of airbrushing problems. It is “the magic solution” to solving a lot of airbrushing headaches and it took me a years to discover this secret to making airbrushing a whole lot easier.
You can thin the paint as much as you want and it still won’t behave when airbrushing. Add a few drops of Airbrush Flow Improver and it should behave a lot better when airbrushing.
Oh my goodness. If only that was true.
Yes Testors OD in a can has been about all I need for years. I don’t doubt that with the huge selection today there are rattle can paints that are a near match to some of the desert colors in the US equipment.
