Source for 1/350 oerlikon
I’ll be building my USS Indianapolis soon and have plans to build my uss england soon as well. I am trying to track down 1/350 oerlikon to replace the kit parts as with them being small the plastic detail isn’t great.
The Indy gets 10 sets of twin cannons and the England 8 singles
Would also want 6xquad 40 mm bofors and a quad 1.1”
good luck with your quest! i will be following your build when it comes time! :grin:
Thanks! Will be my first ships! A bit nerve wracking.
I found black cat models and they seem to have waht I need except the oerlikon have hollow instead of solid bases and I can’t seem to figure out which is correct
can you scratchbuild something?
Could probably use the black cat tops and kit basses
@Mead93 - lots of options here.
If you want resin then Black Cats Models or Kraken Models are your best options (1/350 Weapons)
If your looking for photo etch - the is Big Boy Blue, Infini Models, or Master Models
In the end it might be best with a combination between the options.
David
Perfect thanks for some names I can look into. This is a rookie question but what’s the difference between the hollow base and solid base oerlikons. Possibly in name or period, just so I can do some research on what’s appropriate for my builds
to be honest I am not sure - probably time period if I had to make a guess.
David
https://www.ebay.com/itm/324427702114
I’d go with Micro master and it isn’t too expensive.
