Hi All,
“Two to beam up” 1:12 scale.
Recipe.
Kirk/Spock - are from Mezco and I repainted the face’s, hands and equipment using Vallejo Paints.
Base - has been built using high density foam and balsa wood and the column was made using corrugated cardboard wrapped around PVC pipe and the base and top sections are high density foam. The floor was done using high density foam and the groundwork is a mix of sand and Spak Filla. The bushes are from Woodland Scenics and the small tufts of grass are from Army Painter and the creeping vines are from MiniNatur.
