I’m sorry if this has been asked somewhere else here but does anyone know when we can get black Stynylrez back or who has it all? I want to get it before winter so it doesn’t freeze, I feel like a squirrel ![]()
Ammo MIG One Shot primers used to be the same, not sure if it has changed.
Had a horrible time with that product. The bottom of the bottle turned to a gluey consistency over a few months and I had a real struggle to work with it. It ultimately went in the garbage.
Your experience seems to have differed?
Badger black primer is an excellent acrylic primer. I use it on all my models. However, freezing temperatures transform it into useless goo. It is best to order it during warm months when it will not freeze in a truck or warehouse. That is exactly what the original poster is trying to do, and wisely so.
Water based acrylic paints, in general, have this problem. Most can only go through a small number of freezing cycles before turning into goo. Some acrylic paints cannot even handle one freezing cycle.
There are videos on YouTube explaining how acrylic paints are designed. The producer must balance a number of factors, including how many freezing cycles it can survive.
Alcohol and oil based paints have a much lower freezing point and thus survive cold temperatures better.
I must have been unlucky. The room is in the basement, furnace-heated in winter. My other primers, mostly Vallejo have always been fine.
Perhaps it had frozen in transit.
I used to use it all the time but for a while it became hard to get, especially the black. I switched to Mr. Surfacer but then that became a pain for a while although I managed to pick up several bottles not long ago. I might try it again once I go through the rest of my Surfacer.
