Since I enjoyed the Takom ausf A build, I thought I’d start their ausf B.
I’ll be using the BSK 3D detail set.
A few wheels have their PE rings on after being darkened with AK burnishing fluid. I’ll have to add some putty to the ends as the PE parts are a hair small.
You may as well start a Panzer I marathon like I did with my Panzer III’s a couple years ago.
Great idea!
One side of track is done.
Easy to do but a bit fragile. I’d remove one block but I’m afraid I’ll brake a few doing in doing so.
I think that track tension looks correct.
Thanks, better slightly tight than loose.
Coming together quickly. Guess it helps you built the A just before.
They are simple vehicles!
