The kit comes with a Soviet 100mm cannon but to make it a real Tiran I would rather use a 105mm gun. If anyone has a plastic 105 that they replaced with a metal part I’d happily pay for the part and postage.
Thanks ! -Dan
Thanks KoSprueone, but I’m not an armor guy. I am aware that a lot of serious armor builders will replace the plastic cannons in their kit with metal aftermarket barrels so I was putting out my request for one of the discarded barrels.
For the late-spec Tiran 4 in IDF service you need the 105mm barrel. If you want to make a 100mm IDF version then you need to leave off all the stowage bins and change a few other things. They got the 105 before they got the later bins. The kit OOB is the SLA-specific version. BTW these did not have the 60mm turret mortar. For a proper IDF Tiran you need Miniart.
