By the way, your method of making the paper template was EXTREMELY clever and well executed!!!
I have built this kit using the commercially available wood decks. They work well, look good, and are easy to use. That is the route I would take.
Bill
My Eduard PE set came!! this is the first aftermarket PE set I have ever done so I’m very excited to see the results at the end.
Picked up a Razor saw the other day! my plan is coming together ![]()
the golden rule of modelling
Update on the deck situation!
Still looking very very rough but maybe this can help all of you get an idea of what I’m doing… now that I have traced all these details in pencil on the balsa deck, I can cut out the details from the plastic one and glue them onto the balsa one. Also, I added polystyrene under the balsa deck for reinforcement.
Looking better with every update @hobby1sh ! Can’t wait to see the plastic parts get added.
So I started using a razor saw but realized the blade is too bulky to make some of these cuts separating parts from the deck… for this reason im considering investing in a jeweler’s saw and a mini vise to clamp everything in place… any thoughts?
What type of razor saw are you using ? I think that the type of saw that looks like old double edge razor blades will yield the thinnest kerf available. You may have to use them without a handle or improvise one . If by jewelers saw you mean the type like a coping saw , I believe that these leave a larger kerf than the razor blade type .
I did mean a coping saw yes, are you talking about those micro razor saws that are also hobby knife attachments…? I just fear that something like that would be too small for such a big job that requires this type of accuracy?? I have also seen coping saws being used for similar projects before
I will measure my jeweler saw blades and razor type saws for thickness and let you know what I find .
The Tamiya phot etch razor saws cut very fine lines at .005” and are quite sharp. They come in a couple shapes and lengths. I use them for all my fine cuts
Jewelers saw blade measures .016” thick
Razor type .005”
You can use razor type without handle or improvise - a popsicle stick with double sided tape on one edge will allow you to cut flush.
HTH - RT
Will confirm from experience that these really work a treat. Always pays to have one or two in the toolbox.
Update on the Tirpitz!
I ended up bringing the middle section of the deck to my school and cut it out in the metal shop
I used a coping saw, a hacksaw, and a nice big vise to clamp everything in place and ended up using a razor saw to cut out smaller details and cleaned it all up with Tamiya extra thin, Tamiya plastic putty, a hobby knife and some primer.
The last picture shows what the deck looks like now!
It’s all coming together.
That looks so good jack!!!
Ah hell, that deck actually looks great! Great work @hobby1sh !
Wow! You achieved a great looking deck! Well done!
Bill
