I want to replace the generic Tamiya Skyraider engine but there is not a direct replacement so I need a surrogate.
I do not know the technicalities of the various radial engines.
I want to put in a resin engine and there are several available. The F8F Bearcat, The P 61 Blackwidow, F6F Hellcat, F4U Coursair are available. Is one the equivalent of what the Skyraider used?
Skyraider used a Wright R-3350 Duplex-Cyclone engine same as the B29
MODELSHACK makes a resin one.
Here is a review:
Thank you! I will try to find someone that carries them.
