I recently came into possession of this kit, & am considering whether it is worth upgrading or not.
I read that there are 3 issues with accuracy in this kit. But I am unable to find any information on WHAT those issues are. Does anyone have information on what the accuracy issues are (other than chonky details), and/or fixes?
No.
Build it as is and have fun painting and weathering.
There is so much to upgrade and improve so you might as well start with a better kit instead of spending time and money on the Tamiya kit.
Flat hull bottom with motorisation holes. I don’t know if the lower hull has the correct width or if Tamiya “tweaked” it to fit their motor kit.
In my opinion it’s not that bad a kit; it was also the first 1:35 model I ever built - a long time ago I must admit.
I don’t necessarily think it’s a case of glaring errors, just that much better kits have come along since.
It will still build into a decent model with a careful build and a good paint job, (use a good Gelboliv not a green/olive drab) again, in my opinion(!) I probably wouldn’t bother with the crew figures, they really do need improvement, but again, as Robin says, enjoy it for what it is.
As I say, I built mine a long time ago, but I do recall the tow cables were a bit lacking, being made in “bendy” plastic; at the time I thought the bridge classification plate decal was oversize - I’ve since discovered that the original ones were, indeed, quite large. Motorization holes aren’t really a problem to fix - in fact it’s unlikely they can be seen.
Tracks? Well, to be honest use them, otherwise you’ll be chasing your tail getting replacements.
To sum up: build it as it comes - more or less, and most of all, enjoy it(!)
The tools are very dated in the old Tamiya Leopard 1 kit. While it wouldn’t be strictly accurate, I think some of the tools could be replaced by spare injection molded German WW2 tools.
There probably quiet a few newer molded Pz IV or Panther tools that would look better than whats in the old Tamiya Leopard kit, like wire cutters, axe shovel etc.
