Task Force Grizzly M60A1
The USMC had some mounting Pearson blades.
" U.S. Marine Corps M1A1FEP Abrams Main Battle Tank from Battalion Landing Team 3/8, 26th Marine Expeditionary Unit, participating in a sustainment exercise at Arta beach, Djibouti, November 2010."
Rye Field Models has a kit of it.
Sorry, should have asked if any were used in Desert Storm.
None that I know of.
Is the Tamiya M60A1 with ERA a passable version? I have heard it has some issues but it is ok on the whole ?
Among its issues, the biggest is that the smoke dischargers need to be extended farther from the turret. And easy fix with some Evergreen Rod.
It’s the same old kit underneath the ERA. I’d say the best use for it would be to take the ERA from and stick it onto an Italeri M60A1. Only thing there is that I see that both the Tamiya and Italeri kits cost something like €25–30 each, while a Takom M60A1+ is around €50–55. I would only really take the conversion route if money was an issue and I could get the Tamiya and/or Italeri kits much cheaper than normal.
Im now looking at the Takom M60A1 with dozer blade and ERA or the RFM M1A1 with the blade
Fixed for you. You know that is how it will go. :sunglasses:
