Anyone else having trouble spraying Mig Ammo primers? I use other Mig Ammo paints and they spray fine. Apart from user error.
But their primer drys so fast in the nozzle that it’s one clog after another. Do you thin it or mix in a retarder at all?
bruce
Hello Bruce!
what I do is dilute it with acrylic thinner A.MIG-2000 and if it dries quickly in the nozzle, I remove it with a paper moistened with water pressing a little so that it enters the hole of the airbrush and gives it fluidity. I hope this help you
Regards!
Rodolfo
If you mean Ammo One Shot, no. I have had no troubles using it straight from the bottle. Using a 0.4mm needle.
Thanks. I’m only using around 18-20 psi. Maybe I need to crank it up a bit.
bruce
The only time I ever have had trouble spraying it was when I tryed to thin it. I noticed you got to really mix it well if it’s been sitting around a while. I think I didn’t mixed it very well one time and used the thinner primer on the top of the bottle , after that it seemed to be hard to shoot and I never could get that bottle shooting good again. But all the other bottles have been great and thats all I use now.
