finally had the courage to try airbrushing camo on this warplane, not easy transferring accurate patterns. seems like illustration leaves out parts of the transition between wing and fuselage, so I just guessed on the pattern. lots of trial and error with masking and ended up using 1mm masking tape that made the curves easier to follow. not finished yet but getting there. not the best kit however this is good enough for a novice camo painter.
