Finished!!!
1/35th scale - Trumpeter M1129 Stryker
Very nice job, love the dusty look.
Only one thing that I can see - and I could be wrong- but shouldn’t the inside surface of the rear hatches that you have folded out be green?
Otherwise very nice job ![]()
Yes, the roof hatch interiors should be the same color green as the exterior.
Oherwise, it loooks great
Maybe someone will make am interiors for all Stryker vehicles.
Bummer…my bad.
Great photos by the way.
Should have done my research…
That would be nice!!
This kit has a pretty decent amount of detail, with driving station,equipment,etc..
I think there’s on AM set for an engine.
Thanks.
I just noticed now, with the photos.
Trumpeter doesn’t have a good color profile/scheme.
I found on another modeller’s build at Scalemates…which was also wrong…
I should have done a better research.
As I said before, great job on your Stryker Nitto.
It looks like you can still get to it with an airbrush maybe, you might have to mask some of the other things to keep them from getting paint in them- if you choose to fix it.
If you want good interior color references for all of the Strykers you can’t go wrong with my walk around which has over 1000 photos.
Models have never made good references.
Thanks but now all the other Strykers will be closed up..
Great build! Yes, the hatch interiors should be green, otherwise an exquisite build.
Thanks!!
Great build.
Thanks!!!
Next year I’ll start the M1132’s.
My bench is crowded at the moment…![]()
Great looking Stryker. Well done.
Jim
Well done!
