My understanding is that the primary green color on the Bradleys used by Ukraine is specific to Ukraine and not something used elsewhere. Can anyone direct me to an appropriate FS/RAL/BS green to match it?
TIA
TIA
It appears brighter than NATO Green. I am considering either Tamiya Lacquer Olive Green #2 (LP29) or British Green (LP31).
I did use NATO Green on my Ukraine M142 HIMARS thyough. Once weathered, it came out looking right to me.
Hataka makes a Ukrainian set.HTK-AS112 Modern Ukrainian Army AFV paint set - T-84BM colours - Hataka Hobby Mig makes a set too,but it is from the pre Crimea time frame. ICM has sets for their Ukrainian vehicle kits.
ICM has only one ground vehicle set for Ukraine. It has 4BO Green and US Dark Green.
Hataka has only a Dark Green in their set.
Still not sure which colors are right for Brads.
SWAG: They were refurbed by the US before delivery. I’d think the base would be factory handy FS34079 with Ukraine camo added in country. I think they have better things to do than paint over brand new paint. Just saying …
The dark green in Hatakas Ukraine set is the same “part” number as the 34079 in the “Modern US” set, #016.
Never seen THAT shade of “green” before…
I agree that Forest Green will do, just not sure if it is the actual color or not.
Right, like I said, they were delivered in sand, not green.
I’ve seen several written reports about them and all that spoke to paint said Bronze Green. That was also mentioned in the reports about Australian M1 Abrams newly bought.
Chip
On my browser that looks very much like US OD. I thought Bronze Green (British) was more greener (Olive Green).
Which OD?
Your screen is color compensated for light and shade, yes? (NO- usually)
UK AFVs are painted in NATO colors.
See this chart!
Furthermore, the web is full of data-scatter:
Which of these four is Bronze Green?
As I wrote earlier, the only way to compare is to get the color mix (RGB), hue, etc. that are the elements of color-matching. Here are the different formulae based on your graphics system:
Or you can use the old Mk I eyeball and think to yourself “Hey, that looks a lot like Tamiya XF 65.”
After weathering it wouldn’t have mattered much anyway.
Exactly!
Absolutely
Wow a lot of responses. Thanks to each of you, much appreciated. I think I’ll take another look at the Bronze green and then who knows?
So is Tamiya XF 65 a good match for Bronze Green?
I wouldn’t go so far as to say it’s a match (because it is not) but it sure looks good as the green in the two tone british camo. I’ve used it many times in this way. It’s also a much closer match for the solid green Bradleys in the early 80’s than forest green, IMHO. It also conveniently comes close to some other uses. I hear it can even be used for Wehrmacht uniforms. ![]()
