This is the old Tamyia M60A1 built a number of years ago. I did not like how the vinjett turned out and I also desired to add some figures to make it more “alive”.
I did lower the suspension a bit when I first built it as it sits a bit high. I also added some dents and wear. Inspiration comes from the Concord publication USMC firepower which includes pictures from CAX 89, camp Pendelton.
Well done Ingvar! This is the sort of thing I like doing - updating old kits and trying to get the best from them (even if it all too often, means I spend more than I would have done on a superior kit).
I would say you’ve gotten the best out of this old kit and it looks very good to my eyes, though I know nothing about USMC armour.
Very nice job. Your upgrade really makes this kit pop. The figures may not be correct in your mind but they do add significantly to the scene. Well done.
The last time I was there, we went downhill straddling a small ravine. If you are an armor guy, you can just imagine how the afternoon went with both tracks thrown to the inside, facing downhill.
We broke both tracks. Rolled the tank off to the bottom of the hill. Used the retriever to drag both tracks off the hill to a flat spot and then put the track back on. Waste of an afternoon as everyone else left for the motor pool.
A Great model, I would love to be able to do what you have done. But I have enough problems getting my models done at all, let alone go back and update my old one’s.
Unfortunately I’ve been unable to even get into my shed, yet alone get any modelling done, due to medical problems but I love to read what all you guy’s get up and learn how to do things properly ( or no, in some cases ) . Also it’s great to see the way you all manage to get around problems, that you come across on the models that you make. One of the main things that I most like, is to see how you manage to make and paint such marvellous models and dioramas, it’s inspiring and uplifting .
Try it out. Many times I tend to get stuck on a model I work on to a degree that i fail to see “the big picture”. A bit of rest, sometimes years, on the shelf and I am finally able to see what I should have done from the beginning. A revisit to an already built model do free me from the build process and the initial paint job and can see all the adjustments that needs to be done. It also gives me a new perspective on other projects.
As much as I’d like to show you some of my work, I’m unable too get to my shed, but when I get out side, which I can only hope will be soon, I will take some photos as I can. What I can do this week is try to send you some photos of a little of what I have done and just a little of what I have left to make. I’ll also send you some photos of a few figures that I have on display, as well .
I have had two fires, multiple thrown tracks, sunk in the mud up to the finders. I have seen tank VS car, Tank run into another tank. The gun knocked out of battery. A tank trying to off load from a ferry and push the ferry back and drop into 60 feet of water. I have had my tank tracks frozen to the ground. I have had train cars fail while trying to load on them. I have tried to load onto a truck and trailer and had the truck dangling in the air as the front of the trailer lifted into the air. You always need to remember that the most delicate, breakable thing on a tank is the operator. If you are around tanks for long, you will have stories.
Yup. I saw a LT have to sign a hand receipt for an M1A1 because it was buried in thick mud up to the commander’s cupola and they would have to wait for winter so they could chip it out.
My first day of class the instructor said “The Abrams tank is designed to injure or kill and doesn’t matter who.” Holding up his hand missing his ring finger that was removed in the ammo door track sends an impressionable message.
