US M1151 HMMWV BFGR Sagged Wheel Set | Armorama™
DEF Model recently revamped all their 1/35 scale HMMWV resin wheel sets. This review deals with the set sporting BF Goodrich Baja T/A tire on 24 stud rims.
This is partial text from the full article (usually with photos) at https://armorama.com/news/us-m1151-hmmwv-bfgr-sagged-wheel-set
The previous set is perfect. Except additionnal markings only visible in close-up pics, those new wheels don’t look so different.
I’m not quite sure of the difference between the old and the revamped set. But I do like the idea of upgrading the older sets using new technology…
Do you perhaps have images of the older set used on your model? I would love to see them.
This particular set will be used on my upcoming M1151, so hopefully there will be images of painted and weathered wheels someday.
Mario
Ok I will try to make close-up pics of them.
They are glued on a M1151.
I used the previous set on my M1151 build. DEF is my go-to for wheels.
This is an another thread pattern on your picture.
This is Goodyear Wrangler MT/R tire, not BF Goodrich… but MT/R from DEF Model is the next on my review list. :blush:
Mario
Pictures of the previous set DW35032 on my model.
DEF MODEL box
Front wheel
Rear wheel
Front view of the tire pattern.
M1151 with Def Model wheels.
Looking good, thanks for the photos. Do you remember if the DW35032 wheels were in one piece each? I had an earlier version of DEF Model Good Year Wrangler R/T II wheels (DW35004) and each of those wheels had to be constructed using several pieces:
https://archive.armorama.com/review/6726/index.htm
Mario
I know this set you are talking about, with separate rims. That was not practical because dfficult to obtain a good alignment with tires and when wheels are built there was still a gap around the rim.
That was not a good idea of conception at all ! :thinking:
In the set DW35032, wheels are in 1 piece except hub caps which are provided separately.
Hub caps are the reason I asked… as I think I can see the small gap between the caps and the rim in your set.
Mario
Indeed there is a gap around hub caps.
