Here is another timeline of US vehicle special equipment
The operational timeline from 2001 to the present day captures the complete technological evolution of U.S. ground forces. This window represents a massive operational shift: from the unarmored, soft-skinned vehicle patrols of the early 2000s through the massive counter-IED and troop surge eras, up to modern deployment cycles facing electronic warfare, advanced software-defined jamming, and loitering munitions (drones).
Master Timeline Era Breakdown
- 2001–2005 (The Early War & Vulnerability Era): Ground troops rely on legacy or unarmored HMMWVs (Humvees). Early jammers like the Warlock are rushed into combat but suffer from low power, frequency gaps, and “friendly fire” radio interference.
- 2006–2011 (The Surge & MRAP Revolution): Rapid fielding of heavy V-hulled vehicles (MRAPs) and specialized route-clearance packages. Advanced sensors, high-power jammers (Duke V3, CVRJ), and mechanical standoffs (Rhino, SPARK rollers) become standardized baseline gear.
- 2012–2018 (The Systems Integration & Protocol Era): The military shifts from brute-force “barrage” electronic jamming to smart, protocol-based cyber/electronic warfare. Jammers transition from simple defensive shields into offensive sensors that pinpoint the trigger man’s location.
- 2019–Current Day (The Open-Architecture & C-UAS Era): Threat maps change radically. Vehicles must defeat not only buried mines and RCIEDs, but also overhead FPV drones and loitering munitions. Legacy, single-purpose gear is replaced by Modular Open Systems Approach (MOSA) baselines that use software to change tasks on the fly.
| System / Platform Name | Era & Core Tech Implemented | Active Timeline | Replaced By / Modern Status | Primary Vehicles Used On |
| Warlock Series (Red/Green) | • Analog barrage transmitter • Rushed out to counter early garage-door opener bomb triggers |
2003–2007 | • Phased out completely due to low power and severe military radio fratricide | • Unarmored Humvees • M1114 Up-armored HMMWVs |
| AN/VLQ-12 Duke (V1 through V3) | • Digital Radio Frequency Memory (DRFM) • Wideband active/reactive electronic shield |
2006–2018 | • Modernized sequentially into the software-defined Duke V4/V5 architecture | • Standard baseline on all combat/transport platforms |
| CVRJ (L3Harris Vehicle Jammer) | • 69-pound programmable transceiver • Simultaneous multi-band commercial signal blocking |
2007–2020 | • Integrated into next-gen JCREW and Sabre Fury offensive EW blocks | • MaxxPro, Cougar, & Caiman MRAPs |
| Symphony (Lockheed Martin) | • Open-architecture programmable suite • Designed for non-interference with coalition radio systems |
2006–Present | • Still supported globally; updated to Symphony Block 40 specs to address advanced frequencies | • Multi-national convoy lines • Allied and partner nation platforms |
| Thor III (Sierra Nevada Corp) | • Dismounted three-module manpack system • Frequently mounted to ATVs/patrol rigs for light operations |
2007–2021 | • Maintained for specialized units; supplemented by wearable Baldr and ICREW systems | • Dismounted infantry squads • Light tactical utility vehicles |
| Duke V5 / Sabre Fury Systems | • Protocol-Based Attacks: Infiltrates communication chains to alter ones and zeroes digitally • Dual-use: Jammer + Direction-Finding sensor |
2013–Present | • Current standard; continually updated via U.S. Army reliability and improvement (RMI) kits | • Oshkosh M-ATV • Stryker & M1A2 Abrams variants |
| MADIS / C-UAS Vehicle Suites | • Dedicated Counter-Unmanned Aerial Systems • Integrates 3D radar tracking with electronic kill-switches |
2019–Present | • Emerging permanent Program of Record scaling rapidly across global deployment zones | • Marine JLTV (Joint Light Tactical Vehicle) • M-ATV C-UAS variants |
| Husky Mounted Detection (HMDS) | • Front-mounted NIITEK VISOR Ground-Penetrating Radar • Automated target recognition for low-metal/plastic mines |
2006–Present | • Upgraded continuously; recently received enhanced GPR digital visualization components | • Husky Mark III (M1231) • Husky 2G (Two-seat) |
| Gyrocam VOSS (AN/VSQ-6B) | • 15-inch gyro-stabilized optical sphere on a 20ft mast • Multi-spectral FLIR, day color zoom, night optics |
2006–Present | • Active Program of Record; modernized with GyroLink wireless vehicle-to-vehicle feed sharing | • Buffalo Mine Protected Vehicle • RG-31, RG-33, & Oshkosh M-ATV |
| Boomerang Acoustic Gunshot Locator | • Microscopic/acoustic sensor array tracking supersonic shockwaves • Pinpoints hostile shooter angles inside 2 seconds |
2007–Present | • Current systems integrated with Android Team Awareness Kit (ATAK) software and automated weapon mounts | • HMMWV, Stryker, and heavy MRAP lines |
| Stryker CBRN Suite (M1135 Platform) | • Automated point and standoff detection (JBPDS/JSLSCAD) • Real-time digital mass spectrometry tracking |
2006–Present | • Undergoing modernization via the CBRN Sensor Integration on Robotic Platforms (CSIRP) initiative | • M1135 Stryker Nuclear, Biological, and Chemical Recon vehicle |
| Long-Range Advanced Scout (LRAS3) | • 2nd Gen Long-range thermal mapping and target-handoff GPS | 2006–Present | • Progressively replaced by lighter, lower-power Next Generation FLIR (NGFLIR) vehicle optics | • M1127 Stryker Reconnaissance • M2A3 Bradley Combat Platforms |
| M153 CROWS II / CROWS-J | • Stabilized remote terminal tracking day/thermal sight feeds • Allows crew surveillance and engagement completely under armor |
2007–Present | • Fully active; upgraded to CROWS-J adding target-tracking Javelin anti-tank missile controls | • Stryker fleets, Oshkosh M-ATV, and JLTV |
| Geddes / Rhino IED Heat Inductor | • Front-extended boom box utilizing glow-plugs • Projects a heat aura ahead to detonate Passive Infrared (PIR) bombs early |
2006–2014 | • Phased out as insurgent groups abandoned PIR sensors in favor of pressure pads and command wires | • Broadly bolted onto all front-line armor (Humvees, MRAPs, Strykers) |
| SPARK (Adaptive Roller Kits) | • Heavy modular multi-wheel pressure rollers pushed in front • Explodes pressure-activated targets before wheels touch them |
2007–2021 | • Supplemented/replaced by remote-controlled chassis and full Unmanned Ground Vehicles (UGVs) | • Cougar, MaxxPro, RG-31, & M-ATV |
| Interrogation Boom Arms | • Multi-jointed hydraulic cranes kitted with optical/thermal tips • Used to probe suspected items without dismounting crews |
2006–Present | • Standard mechanical architecture; updated with automated, preset route-clearance scanning loops | • Buffalo Mine Protected Clearance Vehicle • RG-33 Armored Utility lines |
| Panama Route Clearance Trailer | • Remote-control sensor cart towed or pushed ahead of patrols • Uses ground-probing teeth and localized mini-radar matrices |
2008–2015 | • Replaced by untethered, modular tactical ground robots (such as Foster-Miller Talon rigs) | • Buffalo MPCV • RG-31 platforms |
| HIIDE / BAT Biometric Identity Docks | • Fingerprint, iris-scan, and facial recognition mobile database enclosures | 2007–2021 | • Left theater during the 2021 withdrawal; tracking functions shifted to unified digital tactical devices | • Patrol commander units at fixed checkpoints |
| Copperhead (MiniSAR Suite) | • Lightweight Synthetic Aperture Radar tracking terrain shifts via Coherent Change Detection (CCD) | 2009–2020 | • Core radar logic transferred to modern tactical multi-mission drone surveillance pods | • MQ-5B Hunter UAV fleets • Specialized manned task-force airframes |
| Task Force ODIN Sensor Suite | • Electro-optical/Infrared (EO/IR) sky-tracking turrets • Streams real-time aerial feeds down into ground command vehicles |
2006–2014 | • Transitioned to the Army’s permanent Enhanced Medium Altitude Reconnaissance and Surveillance System (EMARSS) | • C-12 Huron airframes • MQ-1 Sky Warrior / Grey Eagle UAVs |
| Desert Owl | • High-altitude airborne GPR mapping command wires and disturbed dirt | 2009–2014 | • Concepts integrated directly into wide-area hyperspectral drone sensors | • Manned King Air tracking rigs • Extended-range scout drones |
| Persistent Threat Detection (PTDS) Blimps | • Tethered low-altitude helium surveillance aerostats • Fed permanent 360° area maps straight to tactical vehicle centers |
2004–2021 | • Dismantled post-withdrawal; replaced by tethered micro-drones and rapid-setup mast systems | • Fixed Base/COP defensive networks • Main Supply Route intersections |
