Sorry! All the vehicles at Augsburg were 70s and later. But one of my favorite tanks to build when I was a kid was a Revell or Testors M48; can’t remember the mark tho.
Right, getting back on track - pun intended - we’re now on to the detail painting:
Still all looks a bit bland, but we’re getting there - hopefully
What’s across the turret face of those tanks? Can’t really tell if it’s tow cables or some kind of hose, looped through the front lifting ring…
As the normal tow cables are still in situ along the hull sides, I can only imagine something like starter leads?
I’d seen the top pic before, but not the other; great pics - and M59s!
Looks like “slave cables”… used to jump start another vehicle with a dead battery.
They really make for a distinct “facial expression” on that M48 turret! I may need to add them to my next build…
Well, be careful what you wish for.
I had hoped that the gloss varnish applied to the model would darken the paint just a shade and once re-matted would look OK – but all I’ve ended up with is a shiny tank in what looks like field grey. I almost wish now that I’d stayed with the Humbrol version (see a few posts back):
So, I’m not really sure of the way ahead; I think I’ll plough on – after all, there’s been a fair bit of work invested – complete it all and see what the result looks like when it’s all matted down.
Hugely disappointing.
Try using a very thin over spray of the original color. By very thin I mean a tint. It may take several coats till you can begin to see the difference. I’ve done this successfully in the past. Good luck.
Interesting that the Revell color took on a grayish tone.
Normally my tin of Revell NATO Olive has a distinct brownish shade of OD.
I used Gunze Aqueous Olive Drab (2) on my M48 which is a semi gloss out of the jar. I think their take on the color really nails the shade
I think I’ll let it dry overnight, run a test patch of matt somewhere where it won’t impede any application of decals, then make a decision on whether to continue or not. I’m not going to keep chasing the error.
After all these years, still learning.
With my previous work using different makers and shades of Olive Green/Drab, what didn’t come out (as I expected it to) right, I used a thin filter of a blue-green oil from 502 and brushed on the model. After drying, it changed the hue to a more acceptable shade.
I know it’s hard to compare shades of color from different photos, but your OD doesn’t look too different from what shows here on a 1964 M60
I take your point - and that looks very like the “field grey” I’ve ended up with! Sadly, I just don’t think it works.
I’ll make a decision in the morning.
I’m still agonising over the colour, not least as in day light it looks different(!)
Anyway, a detail question which I’ve been unable to find the answer to: does the gun crutch have a securing pin and chain anywhere about it? I had thought of leaving such a combo dangling just for a bit of detail.
Thanks!
Whilst I am tempted to curtail the project, I think, all things considered I’ll drive on! I’ve put a fair amount of work into it, sometimes making a rod for my own back, but the end is almost in sight, so I feel “Onwards” is the way!
I’ve also noticed that the colour is noticeably different in daylight; who’d a thunk it eh?
Anyway, this is where I’m at – nearly all the decals on, save the “US Army”/serial numbers which I will apply shortly. I may also apply a stencilled name to one of the kit bags.
Pics below taken in my conservatory, hopefully showing the colour effect of daylight:
Still in gloss varnish as you will notice; once the decals are complete, then it’s time for those washes, followed by some dry brushing. I will also address one of the rear lights, which I’d forgotten about. And, I’ve only just noticed the seams at the top of the rear plate - definitely need attention(!)
Funny, the darker shade in the upper photo is exactly what I want.
