In honor of May the Fourth, I started on this long planned project yesterday, Vader’s flight trio of his Advanced TIE and his two wingmen’s standard TIE Fighters
I’ll be using these kits, while not identical in scale, they are pretty dang close…
I started yesterday giving a base coat of dark gray on the interior surfaces
although I will confess that I am not happy with the color that I used as it dried much darker than what I needed, so a repaint is in order sometime soon…
May the fourth be with you Carlos! This oughta be good!
Looking forward to seeing this. I did a similar thing with the Bandai 1/72 kits.
wow this looks good and i haven’t seen those old AMT fighters being built in years so this should be an interesting subject to follow.
Thanks Klaus. They do look to be fairly simple kits, so the build should be fairly quick (for me)…
Don’t forget this very useful function of those astromechs…
