Hi all,
Long time no see,
I’m after some help please,
. I’m looking to create…but will he finish I hear some ask,
… my interpretation of a Vietnam Firebase SPG bunker.
It’ll be in 1/72nd scale, and have my usual A4 footprint, it’s early days but any help would be greatly appreciated,
In the diagram below it shows a ‘Powder Pit’ (ringed in ‘red’):
My questions are 1) I presume they held propellent for the shells, but how were they constructed, and what dimensions were they, 2) As they’re referred to as a ‘pit’ I’m presuming they were sunk in to the ground, 3) and if so, how did the SPG move in and out of the bunker over the pit as it appears to be in the way on the diagram.
Also, any other suggestions relating to the type of items I should incorporate in and around the bunker, and any online sites I should visit?
As mentioned, it’s early days, and slow progress due to all those sandbags,
, but below are a few images showing some progress.
Thanks for looking, and cheers,
G
From the types of ammo in the diagram, the position is for an M109. The powder pit is a shallow hole to throw the unused powder increments into until they can be disposed of by burning.
Rick
M108, M109 he is within range.
Many of these emplacements were ad hoc setups and not laid out to precise plans. Fire bases were often very temporary and could be adapted to terrain or situations. Wayne
Seems to be a rift in the set-up of your diorama . But you need to realize that those things changed many times during the war so on those plans look at the date they were done so you can pick your timeline.
Because the rivet counters will say that if you are doing a firebase in 1970 , then why is the position set up as per 1968..
Just sayin
Regardless whether the position is for an M108 (with a 105mm howitzer and “semi-fixed” ammunition) or an M109 (with a 155mm howitzer and “separate loading” ammunition), the only use I ever heard of for a “powder pit” was the place to temporarily keep the discarded extra powder charge increments which were not used in firing, until later on for disposal. In Baumholder, Germany in the early 1970’s this was done either at the end of the day, OR just before we moved from a firing point, by lining up all the unused charges on the ground a safe distance from anything that we didn’t want to burn up, cutting one bag open to leave a powder trail to the rest of the bags and burning them on site. I have NO doubt that later on someone decided that wasn’t “safe” and also lost “accountability” for ammunition and required that they be collected and turned in.
And as far as the diagrams for the positions are concerned, please understand that those illustrations from Field Manuals and other documents were ALWAYS considered as “suggestions” as to how to construct and set something up. Unit SOP, the terrain, and the length of time in a position will dictate what firing positions look like.
So pretty much whatever you decide to model, there’s NO WAY someone can say, “That’s not correct”, because it’s almost certain somebody else actually did it that way.
with a great big beautiful
WHOOSH
One time I got to watch the mortar section burn their unused “cheese charges” after a day of shooting. The noise that stuff made was unreal!
Thank you to everyone above for taking the time to read and respond, it’s very much appreciated,
I will start a dedicated thread and post some images as things progress, albeit slowly,
Thanks again and cheers,
G
Here is a powder burn prior to a night move. 155 leftovers, Grafenwohr, Germany, 1978
Going back to the comments made by Tom, ken and Kevin made I’m presuming that creating a ‘powder pit’ as shown on the diagram would be unwise due to the proximity of crew quarters and ammunition stowage,
Would it look better situated outside of the bunker, or would that make it too far from the artillery piece to be practical,
All comments welcomed.
G,
