VT 1-2 versuchstrager
Hermann, Der “Trick” bei denen ist man reklamiert etwas und bekommt den gleichen falschen mist nochmal geschickt weil die garnicht verstehen was du von denen willst…
Stefan, ja sind halt Amis. da werd in mal die Finger von lassen. Danke für den Hinweis.
Chinesen… dann lieber einen von cults nehmen und selbst drucken (bzw drucken lassen wenn man jemanden hat der das erledigt)
Danke. Ich bin mit 3D Druck bedient, nachdem RP Models einige Teile bei einer teuren Figur verwechselt hat. Bin mal gespannt wann der Ersatz aus Portugal kommt?
Don’t you mean the idler wheels?
Fodder for the landfill …
The side view of the hull (see post above) shows 7 positions for road wheels (wheels pressed against the track on the ground).
There are also 4 positions for return rollers (the small wheels carrying the upper run of the track).
Add one sprocket (wheel with teeth, printed in position inside the track) and one idler wheel (the wheel that the track wraps around, not in ground contact on the Leopards and variants).
The “sprue” with the tracks and wheels (road wheels, sprocket wheel)
shows 7 +7 road wheels (OK), 4 + 4 return rollers (OK), 1 + 1 sprocket wheel (printed inside the track with teeth engaging the track links).
It does not show the 2 idlers, on some tanks the idler looks just like the regular road wheels so
if there had been 8 + 8 roadwheels on the sprue it would have worked.
and the gases afterwards are called Dönerwetter?
Asking for a friend …
Never thought about that this way. :rofl:
Erbsen, Bohnen und Linsen lassen den Popo Grinsen?
Looking again at the model (prints?) - the Leo 2K that is - components shown so far, it doesn’t look that bad; the heavy lifting has been done (although that rear hull plate looks nasty); one shouldn’t have to procure a donor kit as well, but perhaps that’s the only way one is going to get there.
The version is interesting enough, especially with that 20mm cannon in a sponson, and I wonder how that has come out, but with a bit of work this might, might I grant you, assemble or rather, result in one of the more fascinating kits one espies on the display tables.
Decals are readily available and Gelboliv will suit it just fine; figures would, as always in my opinion, enhance.
What do others think?
I think it would have been better to produce a conversion set to be used
with a suitable donor kit.
Another possibility:
A French resin kit producer, infamous for his poor customer service, sold
combi-kits with resin parts and the required sprues or parts of sprues from
donor kits.
In conclusion i think there are modelbuilders and modelbuilders. Once we have the in german called “nietenzähler” (rivet counter) others we have the “it looks like xyxy and it is okay for me”
Specialy for the 2K (my opinion) it is to expensive for is what it is - with a lot of work and money i could build it right for me
Another guy would say pretty cool for me…
In begin of this thread i would only give my personaly impressions to let other people know what to expact
No, fair enough; I get that. As we say in English, “Horses for courses”.
I might just take a gamble and see what can be done with it; I am certainly no rivet counter but I do like to be as accurate as I, personally, can manage. To me, it is of sufficient interest, as I recall when images of what was meant to be the Leopard 2 were tantalisingly, published in the military press back in the 70s, and how, as keen young soldiers, we pored over those images!
The leopard kits from amusing hobby gives you extra drive sprockets,road wheels, front ider wheel and front idler mounts because those are all on one sprue and the give you 4 sprues
Your assessment of the products made from gray resin is entirely correct. We previously used other OEM manufacturers to produce our goods. However, as you mentioned, their quality was extremely poor. We have now completely upgraded our products and built our own factory. Please purchase our black resin products. They will provide excellent after-sales service and any customization needs that may be required. Thank you for your purchase.
