Good night. Would you know if this model could have been found during the Battle of Berlin?
They would have been available at that time but how many and where they would have been found I canât say as you see very few photos of them, and you posted one of those few.
Not to be confused with the Katzenwagen of a later era.
Sorry, I couldnât resist⌠I think I have a book on war-time VWs, Iâll take a look.
Unfortunately, no mention in VW at War.
Probably a typo, but the title should be Kastenwagen.
Isnât this vehicle postwar?
Someone wrote: Used by the Luftwaffe on airfields.
Maybe if some Luftwaffe officer tried to use one to escape from the airfield or from Berlin.
Someone else wrote: This was a post-war vehicle
To be honest, searching for Typ 83 pretty much brings up the Special Hobbies kit. I checked a VW source and as mentioned above by Dan and Heavy I can find nothing relating to this vehicle during WWII. The designations I found for a âKastenwagenâ were the Typ 81 and Typ 82. The Typ 81 seems to have been developed from the Typ 62 which was the KDF-version of the standard Beetle and the Typ 82 seems to be based off the Kubelwagen chassis.
In one blog I found someone claimed that the small headlights fitted into some âadapterâ in the larger holes was a post-war solution
Definitely after the war, small headlights mounted in the larger holes
The headlights while Hitler & Co were still in power
Note: This does NOT answer the original question. It only shows that the photo in the first post most likely shows a VW produced during British occupation.
