I’m calling it done, the XM-1 FSED
A lot of work went in to this sucker. The one thing missing is the figure 8 ammo chute on the commanders cupola, I just could not get that thing right.
Looks great ! Especially the CWS hatch prior to the addition of the flat top plate.
Thank you!
Good call. When I get the crew painted I will weather the gloves and boots. Also add some dirt/grease oil to the clothes.
Work from the other day… ![]()
Groundwork progress on the Model T Ford vignette.
Thanks for having a look!
—mike ![]()
Was this the same one you were trying to work out the spare track link stowage on a while back ?
SNOW FENCE !!! Its Baaaaack
That is looking really good too.
Yes, I may still add them at a later date.
Didn’t do it now because I thought I was going to paint it in MERDC, decided not to so as not to clutter up all the work I did
Calling this one done too, the M1E1.
Did a lot on this one too, mostly the turret, modified the mantlet, stowage bins, side rails, blow off panels and bustle rack.
On the hull did the exhaust on the left side, moved the fire extinguisher handle and eliminated the small access hatches on the engine deck.
Awesome abrams fantastic work
Thank you!
Enlighten us ole wise one.
Oof, why the change?
Long story short: Oldest kid moved in her own so we moved wifey’s sewing+arts&craft stuff inside to her room. Then I got the chance to tear down that wall between garage and that storage room(wifeys stuff were here earlier), so that I could fit my summer car(in the pic) to the garage for the winter. Otherwise I would’ve needed to rent some storage space for the car for winter again. Our son will move out in a few years, and after that I can convert his room to my modeling needs
Until that, I’ll try to get by with smaller setup at my computer desk. After getting that garage fully organized, I’ll be able to get my paint booth going on in there..
The very definition of Adapt and overcome. ![]()
Mostly learning some patience and learning what working time I have once I start placing the decal.
I used to dip the decal into the brush cleaning pot till it slide off the paper, sometimes they would drop in the water pot. Now I use a sponge soaked thru and I can dab in some solvent.
This gives me more time to work and a free hand while the decal readys itself. So I paint a little solvent on the model and then place the decal.
Using a decal micro brush I carefully place it as close as I can. Then using a tiny q tip dipped in setting solvent I start working the decal and get it to lay flat as it softens. I dab it a bit to dry it and then let it dry completely before laying a flat coat on top.
Maybe not the correct way but it is working alot better than the water pot tweezers method
Got another Leopard 2A4 kit in 1/35 from Revell for cheap money and I got the idea to build it as a Hungarian Army 2A4. So my question is, does anyone happen to know (especially our hungarian members …
) if there is a decal sheet and painting instruction out for them …? ![]()
Maybe Tamas @Agriamodeling ?
