I just couldn’t resist tackling the M44 today so sans instructions, I set to with the chassis; I’d had a plan in any case to substitute the kit items for better ones from the ancient Tamiya M41 kit; this I duly did but then realised that the trailing-wheel-idler on the M44 was of a larger diameter than the road wheels; after a bit of head scratching I remembered I had an equally old Monogram M48A2 in the stash. It was unlikely that I would ever build it, having already tackled the subject with better kits (which is unlike me!). I thought that a narrowed-down roadwheel might work as the idler and this proved to be the case. The hub details will be added later, as will a Monogram idler as there is one each side- as a support roller - on the M44 which is larger than the rest, so while the M41 versions will suffice for the 3, the Monogram one will work fine for the 4th one. Here’s where we are:
does the rear idler get a hub assembly as well? Are you planning to move that over from the kit part.
Well I’m not going to leave it like that!
The Monogram fitting is somewhat more pronounced than the real thing, so I might have to trim it down, truncate it a bit, then just hope for the lazy modeller’s best friend - mud.
We’ll see.
This is a work in progress, not a build log though I was tempted to run with one; the thing is, perhaps its only those of a certain vintage who even know what the M44 actually is!
Some of the detail is a bit lacking and the print striations prevail, though I’m hoping they’ll diminish once I get around to painting it; that seems like someway off, as without instructions, the crew compartment looks quite challenging. This project is really an experiment to see if I can make something come of it; it only cost me around £30 so not a huge expenditure loss if it comes to that.
Thanks for the interest.
