A strange question at the armor group? I plan on converting a BRDM-1 into a “Hot Rod”. What is the definition of a Hot Rod in the States?
You mean you want to turn this
into that ?
On Wikipedia : https://fr.wikipedia.org/wiki/Hot_rod
Sticking to Soviet-built candidates, here’s another one
Yes, H.P. a kind of. The body of BRDM-1 cries for a tuning.
I’d say … “Hotrods are weird things that I don’t see the attraction or point of” but if you want to turn a BRDM-1 into one, I’d suggest lowering the suspension so that the wheels are almost completely up inside the wheel wells, removing the engine deck and sticking a a big engine with lots of chrome in there (take something like a 1:25 scale car engine, that will probably look good), and remove the vision flaps for the driver so you can replace them by one full-width windscreen. And, of course, paint ugly stylised flames all over it.
As HP pointed out in wiki it’s all over the place but the main take away is “modifying it for greater performance”.
I would probably go with removing “swim” vane, chop the top so it’s a convertible, modify the suspension so it’s lower with nose down attitude, open the engine bay and trick out the engine still 1/35 but with chrome items (maybe add a big blower) and then add a vibrant paint job with or without flames.
Vroom vroom, look forward to your design choices.
I think the more important question is “What is road legal where I live?”. Many U.S. open-wheel Hot-Rods would not be legal in the U.K. as there is a requirement for a certain level of enclosure. There are also pedestrian-safety specifications that rule out some aero packages on tuner cars. The Cybertruck is outright banned because it can in no way be made road-legal in the U.K. (not because it looks like a skip and has the construction standards of a third-world outside sh*t-house). The technical regulations for your region will be somewhere on-line on an official government website, but probably well-hidden…
BRDMs have been converted for civilian use but many have re-militarised (not in their original form) in Ukraine.
Civilianised military vehicles may retain a “pseudo-military” appearance but be modified for convenience; others flaunt their new role with bright paint-jobs.
It even happens to BTRs:
None of these are strictly a Hot Rod, I think the only such item I can recall was from the 1970s; a Daimler Dingo with cut-down armour, big trafficators, on-road tyres on mag wheels and a metal flake (blue? purple? - I can’t remember) paint job.
This may be more your style:
Possibly your best move is improved visibility from the drivers position - big windows, or in this case a bubble-top or convertible. For street-use only a lowered ride-height with large-diameter custom wheels shod with low-profile rubber, donk-style:
and a garish paint-job or wrap:
DO NOT go Bōsōzoku or Itasha:
There’s a difference between customisation and defilement…
M
Talking about hot rod…
The M113A1/2E ‘HOT ROD’ above was fitted with a pair of 440 cu. in. (7.2L) Chrysler RB-440 V8s :
The purpose of converting this M113A1 was to test issues relating to resistance offered by different types of soils rather than producing some kind of super-fast Armored Personnel Carrier ![]()
In September 1979, the Hot Rod reached a speed of 121.92 km/h (75.76 mph) on a 152-meter (500-foot) gravel course at Fort Knox, Kentucky .
In GDR, such vehicle would be called Honecker´s “Heißes Eisen”. ![]()
I guess the intake may obstruct the driver’s view…
No, you can left and right around. ![]()
Your build, your choice… ![]()
Maybe it will be a Mad Max/Zombie/Apocalyptic car with some Masterbox girls around. I let off the sponson wheels and converted the area into fuel tanks.
I was going to say straight pipes, a la Interceptor. (Even if they were fake) When I think hot rod I think of four straight pipes coming from underneath both sides.
However, these are hot rods, taken just this morning on our ride. No pipes!
Okay, this comes close:
My favorite:
A nice little show at the American Legion this morning where, by the way, they would love to host a model club. (reference another current thread)
I also think a $5000 paint job is not necessary to qualify for a hot rod. Pactra used to make a color called Hot Rod Primer. Some cool bulds are simply left in primer.
If I ever tried this type of build I would use an oblong (rectangle with rounded corners) air intake.
Look at the side exhaust on a T-55 or T-72 for inspiration but make it larger, wider at the front (open) end and narrower at the rear.
I would let the exhaust come up through the top plate by the corners of the plate containing the “windshields”
Straight or curved:
Now I am wanting some 1/35 scale muscle cars again.
I like the scoop. A blower would be even better.
You can never be too MAD MAX!
Sorry, but I don’t like the air intake, even though I’ve done something like it myself…
Sorry it’s hard to see, being black-on-black… It’s half of a AV-8B hot exhaust and half of a radome.
I think in this case a power bulge or induction cowl hood might be better:
I also think you should increase the size of the front windows (one-piece windscreen?) and add windows to the sides of the casemate (at least to the panels on either side of the windscreen(s).
Finally, I think the angle of the exhausts should be lowered until the tips above the insulation projects just above the top of the side panels. It might be a problem for side-striping but not if used as a dividing line for a two-tone body. A bit like this but with a straight dividing line, obviously you can use any two colours you like.
Regards,
M
VERY nice, thanx for posting!
M
That’s a dope idea, actually. I’ll be watching.
Another idea i had in my mind was to build a Tamiya M1A2 Abrams to look like the Trump Tank, just to amuse myself. ![]()
Everyone would lose their collective minds if you dropped that on a contest table. ![]()
