Zvezda T90
Been banging away at this for a while. Not a bad kit, dates to around 2005 I think. Plastic is a bit heavy and there no PE. Like Tamiya you get nylon mesh that you have to cut to fit using a provided template. Tracks are link and length and work well enough. Trying to depict a captured vehicle. Hand painted the colors on the gill armor as well as the Z on the turret blocks. Going for a field applied look. Can’t decide if I should add the Z to the side skirts on the panel above the fourth and fifth road wheels. Gonna have to sit it aside until I can get some mud products. Thanks for looking.
Excellent paintwork :+1: !
I think that would look good.
Small update, added the Z to the skirts. Everything flat coated as well. Thanks for looking.
Looks great DV. :+1:
With those markings, it’ll become a target for both parties.
Plan on blanking them out but haven’t decided how best to do it. Different shade of green over the green and black. Just black over both. Green over both. Can’t decide.
“Like Tamiya you get nylon mesh that you have to cut to fit using a provided template.”
This warrants getting the thread flagged as Tamiya-related? Sheesh.
KL
So I over painted the Russian Z markings with a different shade of green. Then, I painted white Ukrainian crosses. None of the markings are neat as they are meant to be field applied by the crew. Can anyone recommend a decent set of figures? Thanks.
Nicely done on the overpainted markings.
As for figs there are Ukrainian tank crew sets in plastic from ICM and Masterbox and Spalah make some resin crew figs.
Done for now. Streaking in the skirts using a fan brush. Dusted up with AB. Exhaust soot pigments. Once I get some mud with grass product I’ll dirty it up some more. Thanks for looking.
