Hi out there,
Does anyone know of a manufacturer who produce 1/16 musical instruments?
I have the guitar and gramaphone from FIRMA49, also the 1/35 Miniart set - from which I will attempt to scale up and scratch build.
Looked across the web, but at present only dollshouse versions at 1/12 are found and look abit too simplified.
I’m not after modern stuff, mainly classical style instruments.
Need something for those between battles/brewing up moments diarama, or just stowed in the corner of a vehicle.
Cheers.
i shared your same thought…I ended up scaling these 1/35 offering up to 1/16 and printing them… worked for me.
Hope this helps.
Steve
Thanks for the reply, but I can’t find the words to justify/plea to SWMBO for a printer.
So it will be the old way, of using the ruler that somehow still causes a curved line and cut fingers - again!
Martyn
There are 3D files on SketchUp that can be adapted for 3D printing. For example, here’s one.
My experience using SketchUp’s 3D drawings on their warehouse often need significant editing to make them printable. It’s too arcane to delve into here, but they can be used, but not as is. Scaling is the easiest part.
