1/48 IDF AH-64 D-I Saraf
I just started working on something completely different for me…aircraft. I chose the Hasegawa AH-64D Longbow kit after the fantastic reviews. The reason for choosing the Apache was
while I was stationed at Ft Hood, the aviation units would constantly be training during my drive home off post. Several times, the pilots would cross a gulley, and pop up across the road surprising driver’s.
The build consists of the Hasegawa Longbow kit, Isracast IDF " Saraf" conversion, and Isradecals IDF aircraft decals. I also picked up quinta studios 3d printed interior set, along w the Master brass pitot / antenna set.
Heres the kit Im using
I mocked up the fuselage halves to check fit…perfectly lined up!!
Quinta seatbelts worked fantastic after I removed the molded details.
I painted the tub a mix of flat black and grimy black…lets be real…everything inside is black on these lol
A quick wash of AK dust was applied for some detail in the recesses
Any feedback or comments welcome !
Looks fantastic so far!! I have the kit in the stash, so I’ll be following along!
Looking good so far. I’ll be following along to see how it comes out.
I am thinking about getting the 1/35 Takom Saraf.
Thanks for following along!
Id love to build a 1/35 Apache…but space is a issue
Great to have ya along
Looking good .
Today I closed up the fuselage after checking the interior fit several times. While the fuse dried, I jumped ahead working on the stub wings. The wings are attached to a robust casting block, and I mistakenly removed the tabs that slot into the fuselage…oops!
The wings are beautifully cast, w postive rivets. Sat - com domes on each side and angled chaff dispensers blended into the wings tell ya this isnt your typical Apache!! They have you add air warning sensors underneath before installing on the body. I ordered the Master brass chain gun/ antenna set, which includes some turned pitot tubes. I removed the kit tubes and will install the brass ones later.
Another change to the kit, was removing a section of the tail spine. Theres a resin chaff/ flare dispenser plug that fits into the hole. Theres actually a panel line to follow making this fairly quick, I just went slow checking the fit often.
The camera showed a slight step Ill need to blend in, but the fit is good !
Last up for tonite was installing the etch screens on the sponsons, then cutting the left side to allow the wing to fit.
Mock up w the new stub wings
Looks nice.
Yeah, I am on the Takom SARAF right niw, but it’s not an easy build…
Started adding the lumpy bits around the helo yesterday that differ it from the US Apache. The Isracast parts fit perfectly in theyre locations, making them seem almost less of a conversion, more like the original kit. I see a few small seams to fill, but the Hasegawa fit has been impeccable .
Looks great. May I recommend that you source the Master or Resikit M230 Chain Gun for it. Both are superior to the kit one.
Floyd
Looking very good!!!
I havent forgetten about this build, Im actually working on the seam cleanup faced by everyone! I worked on removing the rear fuselage seam behind the rotor head, then noticed in the Saraf book Im usingz theres an actual hinged panel…time well spent
Sorry, somehow I missed this post ! I have the Master set to replace the barrel which looks good
