Group Build Title: 90 Years of the DC-3/C-47
Group Build Leader(s): @hudson29
Group Build Description: A campiagn to celebrate 90 years of one of the most important aircraft ever built.
Event Details: December 17, 1935 the first DC-3 took to the air beginning a most remarkable career. Outside of the wright Flyer, it is probably the most important aircraft ever built.
Let’s have a campaign or group build to celebrate this wonderful aircraft. It ought to include civilian & military versions as well as those built by Japan, the Soviet Union or other places. Also versions modded such as the AC-47 and turboprop mods would be welcomed. All scales included.
Start on December 17, 2025 & end on December 31, 2026.
(Remember to click “Going” if you want to join the build!)
Completion Award: [add info about possible award badge here - see help threads for more info]
A Note about Awards: The following text is a reminder that in order for people participating and finishing their projects to receive a badge on their forum profile, they will need to provide their account username to the group build leader by the completion date of the build. The leader will then provide this list to the site admin who will bulk award the badges to those users who have finished the group build. If you don’t provide your username or finish the project on the timetable the leader has setup you will not be able to receive an award.
This should be a lot of fun. I love DC-3s and have an airline version in mind. Are there any kits of DC-2s? If so, I think it would be great to include them.
What do we want for an award?
Paul
If I can get my hands on a Monogram 1/90 AC-47 Puff the Magic Dragon, then I’ll be in!
I built the “Skytrain” version of this kit way back in the 1960s and have fond memories of it. I’ll bet there are other models of the AC-47 out there should you fail to locate the Monogram kit.
I have found that there is a DC-2 kit out in 1/72 scale. It is from MPM and looks good in the box. I have not found any TWA decals for this kit but there are DC-3 decals for a 1937 version. It looks like they could be used for the main marking but would need custom decals to be made for the rego numbers.
Paul
I could probably be talked into building the Roden 144 scale AC-47 as well
I’m in!
Been meaning to do a Dakota for years. Have the Italeri Gunship in the stash and I would like to get an excuse to get Airfix’s new tool. Supposed to be a good kit.
I just received the new tool Airfix kit in the mail today. A quick 30 second scan of the kit in the box shows it to be streets ahead of the Italeri kit with much more subtle detail. I wonder how much trouble it would be to back date it to make a pre-war civil DC-3 . . .
Paul
Would be interesting to see done.
Wonder if someone has done a conversion kit for it?
I had a look at the Airfix C-47 kit last night. It looks really good, just what I was hoping it might be. It is very much a C-47 and would be great for a post war civilian airliner. It will take some research to see what changes would be needed to backdate it to pre-war use. I can see the intakes on top of the cowls would be different and Airfix has made these parts separate easing that job. The cargo door would have to go as well and a passenger door added to one side or the other. Happily, the kit windows do not have the loop holes to allow the troops to fire their personal weapons at the enemy so another job eased.
Paul
Presumably a pre-war civvy would need different seating too?
Was looking at some reviews and was surprised to see that the Dan-Air boxing still has the wartime bench seats along the sides of the interior. Wonder if it’s supposed to represent a cargo carrier rather than passenger?
Yes. Seating might vary quite a bit from example to example. I’m not sure I would bother too much about this in this scale. If the door is closed there might not be all that much visible inside.
Paul
True. Maybe sections of extruded L shaped plastic to give the impression at least through the windows? Would hardly be worth extra expense and work.
Each to his own though.
I see we are not the only ones who have noticed that the DC-3 will turn 90 this year. There is an organization that has formed to raise money to help keep’em flying. They have an excellent logo:
Paul
I have been working on a number of projects including a Minicraft DC-3. It is NOT part of this campaign but I’m showing it here for interest and in hopes that someone might be able to point me in the direction of pre-war and early post-war antennas & DF loops. I have three airliner kits done now but for these small but important details.
This kit is surprisingly well detailed and it is a DC-3 rather than a C-47. There are some issues such as a poor wing/fuselage fit and an odd upward tilt to the nacelles. I corrected the larter by sanding the forward section at an angle to aim the center of thrust in the same direction as the center of forward travel.
The decals printed in Italy by Cartograph were TERRIBLE!!! They were printed sharply and in register and the colors were great – so, what’s not to like? First, they are impossibly brittle and took every opportunity to shatter with even the lightest of touches. Second, there was next to no adhesive – they would not stick unless no positioning was required an almost impossible situation. I ended up taking Elmer’s School Glue and diluting it with warm water and using that to stick’em down. What a PIA!
For the orange areas not covered by the decals or the many areas where the decals shattered into tiny fragments Tamiya rattle can orange sprayed into the cap and brush painted worked reasonably well.
Overall, the model looks pretty good considering my shaky hands and skill level. I will be building another of these Minicraft DC-3 shortly and a Roden DC-3 as well. Wish me luck and do LMK if you know of a good source for those illusive antennas.
Paul
I have been reading various books & internet sources to try to learn about these Douglas Commercial aircraft. One thing that is a bit confusing is the switch from the Wright R-1820 to the Pratt & Whitney R-1830. One source mentioned that it was done at the request of one airline customer. Douglas was OK with this as P&W already had an engineer at the Douglas factory on another job. Why did this airline want the P&Ws?
Another book I’m just finishing now said that the P&Ws offered more power than the Wrights. I find that hard to believe. Both powerplants seemed to be offering similar power in roughly the same time periods.
The P&Ws had a smaller diameter, was there any less drag? They also had 14 cylinders as opposed to the Wrights 9 cylinders. Could the P&Ws have been smoother?
Were the P&Ws cheaper or less maintenance intensive? Did they consume less fuel?
Douglas produced DC-3s with both engines simultaneously - the customers got what they wanted until at some point all aircraft got the P&Ws.
Another book mentioned something I had not thought of. As production of aircraft mounted up during the lead up to WW2, the Wrights were in high demand for military aircraft production. Douglases own SBD for example used them along with many others. Think of all those B-17s which each used 4 of them. The P&W was more available in the foreseeable future and it made sense to standardize on them for DC-3/C-47 production.
What do you think? Multiple sources, multiple answers.
Paul
I got to inspecting an Academy 1/72 B-17C kit the other day and noticed it has two sets (8ea) of cowlings. One set will be needed for the B-17C but the surplus set might be useable to convert one of the DC-3 kits that have the P&W engines to one with the Wrights. I’ll have to compare them with the cowls on the DC-2 kit . . .
Paul
As of today, this campaign is live, let the building begin! We need an award badge still, any ideas? I had a vague notion of a circle with a planform silhouette of a DC-3 but nothing specific as of yet.
I’m still not sure what to build yet. It could be the DC-2 kit in 1/72 or backdating a P&W DC-3/C-47 to a Wright engined prewar liner.
Paul
I’m still not sure what to build for this campaign. Vintage Flyer was working on some decals for pre-war DC-2s but I have not heard how that project is coming along. I have some Pointer Dog decals for pre-war DC-3s which will need a power plant swap. Is anyone else working on anything yet?
Paul
Trying to sort the story of the DC-2/3 has been an interesting process. I have been devouring all the books in my library and seeking online sources as well. One of the first questions was why the Pratt & Whitney engines when the Wrights worked so well?
The answer as I have it now went back to the Boeing 247. Boeing had entered into a combine with P&W, Hamilton Standard & several airlines including their own Boeing Air Transport. These big combines were encouraged by the Post Office who were concerned that small “fly by night” outfits could not reliably deliver their mail.
With these consortiums being customers of each other’s products & services, outsiders were often excluded or relegated to second rate status. When Boeing came out with the revolutionary 247 it was with the full participation of its partner companies. United Airways called the shots and had first dibs on the airplanes.
One of the new 247s was sold to the umbrella organization and sent to P&W who substituted a new 14 cylinder Double Wasp geared engine for the original engine. They found it ran more smoothly, hardly surprising!
With the 247s locked in by the United consortium, other airlines were in a tough spot competively. United was doing great business and others were suffering. Jack Fry of Transcontinental & Western Airways wanted 247s to compete but was told he would have to go to the back of the order line so he contacted Donald Douglas and the DC-1 resulted which was another great leap forward over the 247. The shoe was on the other foot now as far as the competitive situation was concerned and the DC-2 operators had it all over the 247 operators.
To get back to the engines, Douglas chose the Wright engine which at the time was a more mature design than the P&W entry.
While this was going on, the Post Office was taken on the carpet by the new Roosevelt administration for creating the monopolistic combines and the government now wanted them broken up.
United Airlines as the new outfit was renamed, wanted DC-3s but with the new twin row engines from their old partner P&W. The new DC-3 with the new engines was 14 mph faster, flew at higher altitudes and ran a bit smoother into the bargain.
Douglas was happy to install whatever the customer wanted until wartime priorities sent the Wrights elsewhere.
Paul
