That first one on the left may scrapp away with a #15 style blade with minimal hassle.
What Robin mentioned for the others.
Very nice build, I’m enjoying following along. A++
A small piece of fine sandpaper glued to the end of a wood stick and a lot of elbow grease.
Scraping with a knife dulls the blade and leave marks that need to be sanded down →
go straight for the sandpaper.
The end of the stick can be cut at an angle, can be useful to access hard to reach areas.
Do you have a motor tool like a Dremel? A small grinding bit on low speed setting and a light touch will eliminate those marks, then a bit of strip styrene to replace the cross member and you’re golden.
Thanks @Uncle-Heavy , @d6mst0 , @Armor_Buff , @Stikpusher . I will keep you all suggestions in mind.
Ben~
