Acetone baths for 3d printed items
Hi fellow modelers,
A friend of mine has been doing 3d printing now for approximately 2-3 years. He has been sending me all sorts of subjects in the figures and busts category. His work is very good but unfortunately he hasn’t mastered the art totally.
So when he sends me stuff the details are very clean, but there’s a lot of lines were the resin was being processed into the items.
My question to you guys is this, I was told that you have to do a acetone bath to smooth out those lines.
  1. what is an acetone bath?
  2. Do you submerge your pieces in the acetone?
  3. How much acetone will it take to do this procedure using 75mm and larger figures/busts?
Thank you for any and all information.
Hi, never heard of acetone bath, not to mention acetone is very strong chemical to work with resin. Usually if you print at lower layer height, after priming and painting the layers will not be visible.
Regards
FWIW, I think you may have been given some advice that confuses a couple of processes.
Most 3D printers use isopropyl alcohol to wash the excess printing resin off of the items before they are post-cured in UV light. (There is also a class of 3D printer resins that are water washable, but I suspect that’s not what you’re dealing with, here.)
The lines that you’re referring to are often called “layer lines,” and they are artifacts created by the limited printing resolution of some machines. Angled surfaces and compound curves are subject to a “stepping” effect as the printer finishes one layer and then stacks the next on top of it. What can be the visible result are lines formed by the edges of the layers.
Some newer printers and updated software use features called “anti-aliasing” to essentially print an extra “half layer” around the edges of each normal layer, but the best cure is to print with higher resolutions (thinner layers with less visible lines around them) or to use true SLA laser printers (that expose and cure the layers one voxel (think 3D “pixel”) at a time.
However, for items that have already been printed, and that have visible layer lines, there’s no “un-ringing that bell.” The only cure is to either physically blend the lines by sanding or filing, or to fill the lines by applying a heavy primer paint (or some combination of both).
Consider: If you were able to “wash away” the layer lines by submerging in acetone, you would also wash away all of the similar resolution details on the model (edges of buttons, belts, insignia, etc., etc.). This is also one of the problems with trying to fill the lines with heavy paints or primers - what fills the layer lines also muddies the desired details unless the filler is carefully brushed on just in the places it is needed.
The bottom line is that there are no shortcuts, just lots of a new kind of parts prep. Instead of removing mold seam lines, injector pin marks, filling seams, etc., you’re now carefully sanding, scraping and filling layer lines.
Not all 3D prints are made equal, so informed purchasing is the order of the day (and one reason why good reviews of 3D models, parts and figures should have macro images of the surfaces).
As I recall, there is a procedure using acetone to “smooth” the surface. That is where my knowledge stops. It may involve a fog or fumes as opposed to dipping. I am sure it was for a specific need as compared to a general do it for any print.
3D Print Smoothing Guide: Acetone Vapor, ABS & ASA Safety
Reading through this, it is NOT something you should do at home. Even the website says this:
Smith3D does not recommend treating a DIY container as a safe process. Safe use requires controls based on the SDS [safety data sheet], solvent quantity, ventilation, ignition sources, electrical classification, PPE, storage and waste handling.
The method is for industrial setting with engineering controls and PPE.
As others said, the safe route is wet sanding and primer coat.
For those who do not know, I work for chemical industry and have a chemistry degree (in addition to being a 3D print enthusiast), and can confirm how hazardous acetone is.
Breathing in a lot of acetone at a prolonged amount of time will literally kills you!
Not only that, acetone is highly flammable, and a small ignition source can cause a house fire easily.
Not to mention all sorts of illnesses it can cause at chronic exposures..
See this SDS for reference. https://www.sigmaaldrich.com/sds/sigald/32201?srsltid=AfmBOopTKeaAq5MiwchnOTg4H2HNJmsRu3BeECVTiFCr16x2wm6LpL3N
Inhalation (Vapor): LC = lethal concentration
  • Rat LC50: 50,100 mg/m³ (over 8 hours)
  • Mouse LC50: 44,000 mg/m³ (over 4 hours)
Anyway, this is just a hobby. It is not worth your health, life, and burdening your loved ones.
It reminded me of Lichtenberg burning art that killed dozens of people a few years ago - remember that?
Acetone bath, vapor, spray, whatever you are tempted to do just to get rid of some barely visible 3D print lines, I highly discourage it. Please, it’s not worth it.
Much safer and easier to use a higher resolution 3D printer, tinker with the print settings, wet sand, and primer coat.
