I have had issues lately with paint drying between the needle and the washer that prevents anything from entering the handle. I clean the paint out of the cup and blow a couple of bowls of lacquer thinner through the airbrush. The next day the needle is stuck with dried paint. This happens with my Iwata Eclipse. Why is the paint moving to that part of the airbrush and solutions you found to address this.
How old is the brush? Maybe the washer has worn down just enough to start letting paint slip through?
Maybe 30 hours.
This happening to a new airbrush really makes me scratch my head. What paints are you using and what’s the ratio of paint to thinner and are you sure the needle is set correctly and is the washer nicked?
I used the eclipse for a few years and never had an issue like this . But my favorite was my old Binks Wren.. just sayin
Do you backflush the airbrush when cleaning?
This is a good video that can be applied to any airbrush, although coming from H&S:
Backflush is on 06:30
From time to time, you have to break the Airbrush down and swab the inside with A small Pipe Cleaner dipped in solvent; Soak the Nozzle while you’re doing that, and don’t forget to wipe down the needle; Then, Re assemble the brush and blow some thinner through it to see how it goes. It’s A good idea to keep some spare parts handy.
there is a needle packing screw there on Iwatas, if you use a small screwdriver and turn it slightly clockwise after taking the airbrush apart, you can control the leakage of paint. Take it apart, clean with brushes, ultrasonic bath, whatever you have, then when you insert the needle try and feel for resistance. If no resistance, turn the packing screw clockwise about an 1/8th of a turn. Try again. if too much resistance or if you cannot push the needle through, back off the screw. There are even some very specific tools for this, but a small screwdriver does the job.
Here is IWATAS instruction on replacuing it and adjusting.
it is the needle packing screw
I will reseat mine and see if things improve.
please report back. While I’m confident this is the issue, I am less confident about that than my language suggested. It seems like with the airbrush I keep learning additional causes for things I think I understand…
I reseated the needle packing and things were better, less paint in the back of the airbrush where the needle slides through the needle packing.
