I am building a Italian Eurofighter for the Twin Engine build.
In a hobby store I found on a visit to my friends I found the color I needed.
LifeColor Sky Grey 16 (22ml) FS 36280
The thing is the store did not have any LifeColor thinner.
I have looked online and found some suggestions on the best way to thin it but I want to open it up to this community.
Have you airbrushed LifeColor paints and what Best practices have you used.
What have you used for thinning the paint?
LifeColor recommends airbrushing at low pressure. Some LifeColors are thicker than others so I adjust the psi as needed. LifeColor also suggests multiple thin coats.
LifeColor thinner and cleaner work best but I’ve had success with water. To clean it, my experience is Simple Green works great. Just keep protecting your eyes and don’t aspirate it. I don’t know what it in Simple Green but it is not meant to be ionized and inhaled.
Ultimate thinner also works great, honestly Lifecolor are one of the best pure acrylics for airbrushing, after much experience with Vallejo, Scale75, AK and others
Life color paints are my favorite. They spray well and don’t lift off as does Tamiya when brushing, I think that I get better results using Life colors thinner tho I have used distilled water. I use IPA to clean my airbrush, spraying it into a cleaning station. IPA will also take off life color and Tamiya paint when needed.
