Here are some pictures of the resin barrel. The last one is a comparison of the Takom gun and the FC Modeltrend one. To have the FC barrel fit the mantlet you’ll have to fully drill the opening and remove the flat part.
That was my first thought but I just couldn’t figure out to make a correct muzzle brake.
FC rendering is not perfect in shape and the caliber is still oversized but it looks way better. I’m pretty sure no one will notice the caliber at first sight. Another option would be to use a muzzle cover as seen on many pictures of the Argentinian tanks.
I wonder what the outside diameter dimensions are for the 105 mm actually are?
The new resin one may have used the same diameter as the kit so that it would fit into the mantle.
Hi Olivier, I would heartily second that - fabulous builds and paintwork. I also appreciate the information about the 105mm barrel and the AMX-13/105 generally. This will come in very handy when I tackle the Takom kit. Thanks!
Just had a very pleasant catch up on this thread Olivier, thanks for pointing me this way. Three very impressive builds. This is certainly a reference source for when I build my two Takom AMX-13!
