tread patterns
The way the tread pattern is arranged on my build is because of some pictures where this is one
(for discussion purpose only)
Most of the latest version of FH77BW L52 seem to have the tread pattern arranged this way. The picture showing the right side (above) is an earlier version, (-the round black object in front of the wheel and also the position lights on the side).
I happen to have the I-book for Pvpjtgb1111 (a light jeep with a 90mm recoilless gun) and on page 40 it actually instructs to turn the tire arrow pattern opposite between the rear and front axle. They don’t tell why though. It is however opposite to the way the tire pattern is turned on the Archer. I can only speculate on why that is, -one reason may be that Archer is much heavier than Pvpjtgb1111 and also that the tire pattern on the light jeep is not the same as the Archer albeit both being identified as arrow pattern. The width of the tires may also affect how they interact with the terrain.
I totally accept your reason for arranging the patterns the way you did.
Nearly all the pictures I could find showed them that way, some were hard
to interpret …
It looks impressive.
