The bridge is gonna be tough. As depicted in the painting, the tanks are on what amounts to an elevated roadway before the start of the actual bridge. Building the support structure under it will be difficult. Otherwise, it will just look like a section of road. You could move the tank onto the bridge itself, then you could use some Plastruct girders to add a bit of the support structure.
@tankerken yeah that’s the tricky part i had originally planned on doing it on a base with the bridge coming off the base and not depicting any of the street below. I may still do that but I’ve also seen some elevated highway dios where they show the girders and nothing underneath that, this may be my best option at the moment. I am thinking that where the second tiger is in the picture, right where the arch begins is what I’ll depict with only the first two columns on each side visible and the arch slowly rising, this should be doable and can actually make the dio smaller but not cramped.
Edit: the place circled in yellow is the portion of the bridge I’d like to build.
