Goodies from 3D-Wild thanks to @Small_Designer craft work on here.
Quality is outstandingly good, i am looking forward to tinkering with these kits.
Tagging people:
Just type the at-sign and the first few letters of the “callsign”.
Like this @Punchinpaper
Thank you for the assist.
Very interesting, looks good, but you haven’t mentioned errr what it is?
Rather “what they are”.
I see three armoured cabs, two of which are very similar, the third might be the same,
maybe FMTV/LMTV,
upper right (hood/bonnet) looks like the front of an M1070A1.
The mudguards (lower right corner) looks like M1070A1 as well.
Thanks Modern US kit isn’t my speciality
They look to be some of the 3D printed parts designed by Small Designed, as seen here:
3D HEMTT A4 Conversion Parts in the Works - Armor/AFV / Modern - KitMaker Network
Not mine either, there is simply too much to keep track of …
2 armored cabs with marine corps turret, I am curious to see one of those kits built.
The MCTAGS looks casted differently than Live Resin or Legend Productions turret with side walls solidar to a half rear wall.
Silly of me to forget to put that in the post.
Somtimes my head and brain are truly disconnected.
Well here we go
-HobbyBoss HET M1070A1 Set
-HobbyBoss HET M1070 Engine Set
-HEMTT CROPS
-LVSR Suspension upgrade (12 of each)
-LVSR Cabin Armored with MCTAGS
-MCTAGS
-one extra mis printed LVSR Cabin that has failed to print fully but other components did.
I plan on ordering stryker and HEMTT kits soon because the quality of thes kits are next level.
