Build a Photo 3
Base coat down and some detail painting started.
I also assembled and base coated the large shield for the Bison. Dragon give you 2 versions but don’t explain which to use. I could not work out the difference apart from one extra small bolt on the top side - until I painted the one I selected. Seems that one shield has has very faint raised marks for where the brackets for the spare wheels are to be fitted. Of course that is not the one I needed for this project! I have sanded off the marks and base painted that assembly again.
Great progress from the southern hemisphere with Peter @petbat and Sam @SamS … Both builds coming on really nicely guys … Keep at it :+1:
Thanks John
Gun shield touched up where I had to sand of the bracket guides and decals are down:
Next a flat coat then more detail painting.
That’s built up really well Peter. Not really looked into this vehicle if I’m honest, so do the wheels just get removed on the gun, and then it uses the axles on some type of mount inside the shield/body area ?
The gun is craned into place as a standard field piece, wheels and all. There is a cylindrical fitting that the towing eye is fitted onto and there are two ‘bins’ for the wheels to sit in. A pin went through the sides and through the spokes to lock it in place.
The hubs of the gun fit into holes in the side of the armour, and there were ‘ovalish’ covers that were fitted onto the armour plate as per the pic above. This diagram has the wheel hub eye pointed down, when it had to be horizontal to fit in the housing. It also shows two pins, not one like it should, but you get the gist of things anyway.
The gun being craned into place ( I contemplated doing this pic):
A wider shot of the pic I am doing:
I didn’t have the courage to do this one :rofl: :
Cheers for the explanation… Very ingenious… :+1:
Decided to jump to the figure. I have a tendency to procrastinate on finishing figures for my builds, so instead of leaving it to last, I forced myself to get into it now. I also forced myself to get on with the backlog for other builds too…
Not finished yet, but getting there. Also doing the wicker ammunition containers too:
Weathering of the Bison 1 has also been started:
I noticed the photo vehicle has no radio antennae base, so I removed that from mine and touched that up.
Dragon’s muzzle cap is the type with a raised disk in the centre. I notice the one on the Bison in the photo is the other type, so I scraped that off.
Great idea with the figures and moving them up in the process … They are always where I fall flat …
Us and the vast majority of armour modellers I would say. :wink:
Oh how I envy the ones who are good at it !!
Practice.
“Practice makes Perfect”… but in my case, “Practice doesn’t make perfect if you’re doing it wrong”…
Yes, but with practice you can be consistently wrong! :rofl:
“Procrastination” has way more syllables and it’s more fun to say, therefore it wins. :face_with_hand_over_mouth:
Procrastinators of the World
UNITE!!!
oh sorry, maybe tomorrow
there’s an anthem:
Ah a classic from my youth…
At least one thread with some help.
Yeah, I entered that one. A lot of really great models were finished in that and the prior one. My humble effort:
I did better with the two medals for the builds :rofl:
