Now for the rear parts.
Well that was long.
Finished for now.
Donald
Donald, you’ve made the interior look fantastic! Very sweet!
Really appreciate you sharing the build.
A+++
I’m glad that you like it, but you haven’t seen anything yet.
Regards
Donald
Looking good overall. Did you add the pedals for the driver?
That is the transfer case.
Very nice work so far. Looks like there were two different iterations of the instruments panel. As for the speedo, I wouldn’t sweat it, They didn’t get the decal right in any case. 80 mph!
I recently got my hands on the 1/35 version of the M20 Armored Car; truly itching to get the 1/35 M8 to have the duo together. Both Tamiya. This one will be a good thread for references until I get my hands on the 1/16 scale one. ![]()
Following this build, looks great, but wayyyy to big for me, I’m out of shelf space now! lol, but I’d love a full set of decals for a WW2 3d Cavalry M8
Just the Gas Pedal .
Not too much today.
I think I am going to build it without the rear fenders, for something different.
Maby I’ll get more finished tomorrow.
Donald
Well I finally got the Hull and wheels painted & the wheels installed.
Here is how I did it.
I’ll be working on the Turret next.
Regards
Donald
I also bought this kit on pre-order from Andy’s HHQ, and have not started it yet. I was surprised to read above that both brake and clutch pedals didn’t make the trip, as well as at least one fuel/water can.
I believe the ammo rack is also missing. I haven’t seen it above or in the instructions online. I think it’s supposed to be behind the driver. Was that added/removed during the production run?
The Ammo rack is built in on one side between the Wheels , There are 2 ready racks that go on the inside of the Turret Shell. I haven’t got that far , I’m having a hard time getting the 50cal. Mg. ring to fit right. The mount spots just don’t want to line up
As you can see above I have done the Turret basket separate from the Turret Shell for painting purposes .
The Turret will be Olive Drab and the Basket white.
I plan on doing the ready racks separate with the AMMO then install at the finish.
The Water can that i used is from the 1/16th. Sherman.
Regards
Donald
Thanks Donald. ![]()
I think that I finally figured out the 50Cal. Mg. Ring Mount, here is what I have.
It/s not jlued down wet as I still have a lot to do, but it’s moving along.
Regards
Donald
Nice catch on the .50 cal mount assy.
I haven’t got to it yet to show that there should be a space of 12mm. between the top of the Turret shell and the bottom of the Gun Ring. This space is needed to fit the Value Gear parts. Of course if you aren’t using them then it can be smaller, but not bigger.
Regards
Donald
I have some more finished.
First the 50Cal. Mg. It doesn’t look to bad from a distance but up close I’m not to happy with it.
Here they are mounted in place.
While searching on the net I found this.
