Building Andys 1/16th Sherman
Aw go ahead and buy one, I bought 2
They cost just a little more than some of the new Trumpeter and Hobby Boss kits.
Installed the Return Rollers & Wheels. I got a nice friction fit on the wheels so I didn’t have to use glue there. The Return Rollers need glue just be shure the inner ones are all the way in.
Here’s the Pics.
The Track is next , a lot of parts to clean up.
Regards
Donald
I have the Track mostly cleaned up .
Now to assemble it all.
Regards
Donald
I have the Tracks together. I found it rather easy , First hold one of the outer parts face up , then clip onto the pins from the bottom one of the inner parts.
Next place the adhesive sparingly around the raised edge then slip on another exterior part and squeeze together , continuing on inner - outer- inner and so on.
I assembled the track in sections of 10 and 1 of 7. Then assembled the sections into 20 count assemblies and 1 of 17 for each side.
The pictures should explain it.
Regards
Donald
The Track is finished and installed.
Here’s how I did it.
I joined the Track over the Sprocket so the Sprocket would hold the inner part of the Track
You have to be careful on adjusting the Track tension , too tight and the front and rear Bogies will not set level.
Heres Wishing You All the BEST NEW YEAR EVER
Donald
Really enjoying this,looking good.
Thanks for guiding us through this very enjoyable build Donald. I have this kit and have been happily following. Take some time out tonight for some New Years frivolity!
I’m glad you like it , I’m still thinking about the pioneer Tool Tye down problem.
The kit gives you some really nice tools and tie down eyelets but no straps.
It would be nice and very profitable if someone would come up with some tools with printed tie down straps.
oh well I can always wish.
Donald
@oldwarloke that square could be the escape hatch on the bottom of the hull.
Nope I checked , The escape hatch is under the Bow Gunners position.
Maby Andy could explane it. To me it looks like a modification to ease molding the lower hull.
Donald
Its just a mould thing, the Das Werk Stugs and panzer III have the same, just how Takom produce the tubs.
Keith.
A little early for me but hear’s something missing from Andy’s Sherman.
sherman external fire extuingsher
a little dark , I scratched it , I’ll show it next post.
Donald
I have a little more finished. I have found a mistake In step 5 of the instructions the two mounts for the rear fenders aren’t numbered just shown in place .
See Pic #ch-53
Pic #54 shows how the M15 parts go.
Still working
Donald
Make that R28 & R29 My mistake
I’ve been doing some painting ,
And so it continues.
Donald
#56 - Is that the elusive Sherman comb I see on that final drive cover? Did you make that or does it come in the kit? If it’s in the kit this will be the first time in history that a manufacturer has recognized it’s ubiquitous existence and provided the part in a kit!
Yes it comes with the kit , I was suprised to see it as most builders don;t know what it was fore. For all of you who don;t know , When shipping a sherman cables were run through the bow Mg. mount to the brake mechanism inside to set the brakes. When they wanted to move the tank they released the cables releasing the brake. That is according to the book Son of Sherman.
Regards
Donald
Now for some more building.
While waiting for the paint to dry I assembled part of the main gun.
A lot of seam filling is needed here.
Also the 2 parts #L17 need to be drilled out using either a #41 or #42 drill the fit is almost imposible otherwise.
Regards
Donald
Gun is ready to be installed in the Turret.
Excellent,hoping the Tiger kit looks as good.
Very interesting to see the large Sheman going together! Thank you for sharing the build.
