I just can’t stay away from these big ones. Well here I’ll build the late WW2 / Korean war
1/16th. Sherman from Andy.
A lot of the parts are the same , but there’s a lot different and this time I’ll be adding some of the Value Gear to it. I’m still not quite Shure if I should go Late WW2 or switch to Korea.
Oh well here’s the start.
Now I continue on. I am trying to put as much of the relevant info on each picture so those of you if any , save them you will have what you need to know.
Now continuing .
I have the Trucks , Wheels and Sprockets assembled.
But first here are some pics from the first Andys Sherman that I built here.
They must have done some work on the Molds for the Truck parts , Wheels and axles as the newer kit has a lot better fit.
OK
First in the older kit the Axles wouldn’t fit the Wheel Bushings or Wheels.
Installing the Wheels and Trucks.
First off the Korea version has been improved over the first early issue of this kit.
The Wheels and axles actually fit over having to drill out the Wheels , wheel bushings and Frame that the axles go through.
Here I installed the Return Rollers and removed the masking where the Trucks mount.
Gluing is a lot easier when you don’t have a layer of paint between the parts you want to join.
Well after a three day struggle I finally have the Track assembled and installed.
I’ll be showing 2 ways of assembling the Track. You choose what works for you.
First the Free-hand method without the supplied jig,
I have some of the Turret inside & Gun finished.
There’s no reason to get too fancy here as most of it can’t be seen once the Upper & Lower halves are joined together.
