Group Build Description: Any tracked vehicle but a tank.
Think about ARV’s IFV’s, Amtracks, SPG’s, Bulldozers, etc. Basically it should not have a rotating turret with a main gun designed for direct fire and (relatively) heavy armored. Tank destroyers, like M10 or M36 are an exception to the rule, but the early British rhomboid ones not, as the turret had not been introduced yet. But I think most of you guys know well enough if something qualifies as a tank or not.
Event Details: (Remember to click “Going” if you want to join the build!)
Like a Cruiser AA, Wirbelwind or Sgt. York? Sure! Though they use the chassis of a tank, they have a special role, unlike the tank, which is considered multi-role.
Yep or a ZSU 52 etc? Also what about something like a Stug that has the main gun assembly made, casement roof, partial rear deck and lower hull and some wheels made, but not put together?
A tank is a fully tracked, fully enclosed, fully armored vehicle with any form of gun, including a machine gun. That meets the original definition of tank as defined by the British people who introduced the term.
That definition might have been correct in the beginning, but a tank destroyer is not considered a tank, as it has a dedicated role in only destroying tanks. Tank destroyers, aa tanks and the like were not even thought of yet, so the definition shifted in time.
Not counting tracks (200) scalemates says there are 378 parts, for ease of math, I will round up to 400, but dismiss (178) track parts, I don’t believe that I have assembled 100 parts, have I cut about 100 parts of the sprues, would be close, but about half of them still require cleaning up etc. But I am happy to abide by your choice, I do have other options if I decide to join in.
It is your campaign! You have compete control of what qualifies and what does not.
I was commenting on the fundamental question of what “tank” means. There are a lot of definitions out there and many people clearly struggle with the concept.
The definition should encompass the machine the term was coined for. Clearly, if a given definition does not encompass a British Mark I Tank, that definition cannot be correct. For this reason, requiring a turret is out.
I also feel the inventors of the term have far more precedence for definition value than people who come along later. It does not matter what some Major or Public Relations person thinks. The original meaning based on the ideas of the people who coined the term should have precedence.
“Tank destroyer” is an interesting term because it is a role, not a machine body plan.
To be clear, I really like the campaign idea! It covers a lot of ground and stimulates discussion of a very interesting question. What is a tank?
I will build a Tamiya RSO when the time comes–the tracked truck version, not the tank destroyer version. Unless I change my mind, of course.
I get where you are coming from and don’t want to end up in an do-do not argument at all, but initial definitions do shift over time. A Little Willy, Whippet, Mark 1 to 5 or A7V are originally incepted as tanks. And the original definition certainly applies to them. But if you keep at this, a M113 ACAV will be counted in too: it is all round (lightly, but so was a Renault FT) armoured, tracked and has a machinegun. Less knowledgeable people would call it a tank, I know (heck, they even call a Fennek wheeled armoured recce vehicle a tank) but it obviously is not.
As for the tankdestroyer, is indeed is a role, but the role clearly has spawned several dedicated designs: M10, M36, Panzerjager 4, Jagdpanther, Hetzer, Jagdtiger, Elefand (Ferdinand), etc. So you can also call it a category of vehicles.
The RSO (Raupenschlepper Ost, not Rad Schlepper Ost (just to differentiate)) will fit perfectly ofcourse!
