Ben working on Hobby Boss’s XM706 for the last few weeks and got down to the last stages, squirted AK’s clear flat but couldn’t get it flat, it was nearly as glossy as the gloss over coat, aarrrgh! Studied the site and the net and decided to try Rustoleum clear flat and this is what I got . . .
. . . figures, rite! I went to Lowes for Krylon but none on shelf, remembered someone on the forum using Rusto to finish their rail cars so I tried that, well poot!
@agincajun Terry, I once had something similar happen with a T-72. Fixed it with Pactra A48 Clear Flat.
Pactra’s A48 been gone for along time and difficult to find now but I think @SSGToms Matt’s acrylic flat will work equally well to correct the gloss issue.
I used the recipe @Armor_Buff refercnws and it worked well! Make sure to test it on scrap as a poor mix can lead to frosting. I couldn’t get an absolute dead flat but it was close and the filter flattened it
Yes dear, browse thru this post . . Practice Weathering Part II . . . this is weathering we all aspire to I’m sure, Dave @Kraftstoff3 used Rusto on his works if I remember correctly and they look flippin’ awesome, why my application didn’t work I dunno but one has to be sure to use the exact same product to get the exact same results, I may have failed in that respect
BTW Joe, what are you using to get a flat finish? I’ve tried Model Master, Floquil, AK Real and now Rustoleum, if you tell me you’re useing RightGuard antipersperant and show a picture where it worked I’d consider it.
Once a solvent enamel/lacquer base flat coat goes GLOSS and is jacked up, I’ve found it impossible to fix a glossy solvent enamel/lacquer base flat with additional applications of solvent enamel/lacquer base flats regardless of brand.
Switching to a very high quality acrylic flat will work most of the time.
Thanks to a bad can of Testor’s Dulcoat back in 1993 this T-72 turned shiny and glossy like a freshly waxed new car. None of various enamel/lacquer flats would even slightly dull the gloss.
Two coats of Pactra Acrylic Flat fixed the gloss issue.
That’s the annoying thing about varnish- it’s a strangely tricky thing that can go wrong with no rhyme or reason. I’ve found this to my cost multiple times- that’s why I tend to prefer the easiest solution which, for me, is a varnish you can airbrush or paint straight from the bottle.
And it’s 2021. Someone else already did that trial and error for you.
I’d not seen anyone mention Rust-o-leum and Krylon mattes in these forums and I have been visiting for years. Mostly Pledge/Future variations and your Modeling companies’ solutions.
So, yeah, it’s a bit freaking odd to me.
“I’m going to spray the same paint on my deck furniture AND my model kits.”
I use Windsor and Newton Galleria Matt Varnish. Thin it 50/50 with Tamiya x20a and spray away. The most Matt finish I have ever used. It is supposed to be removable so I only use it as a final coat.
Sorry I’m a little late to the party. I was at the hotel today finalizing everything for Armorcon.
So, for a dead flat (and I mean that) finish that can’t be beat, mix 70% Future with 30% Tamiya X-21 Flat Base. If that’s not flat enough for you, you can even go 60/40. Shoot it straight from the bottle at 15 PSI with a .5 nozzle (or thereabouts) and you will have a beautiful airbrushed dead flat finish that will not frost or milk on you and will stand up to all the oil or enamel weathering you can throw at it. Here’s a few photos of models with this flat coat -
Just use a Sharpie to mark an empty bottle into 10 sections and mixing is easy. I’ve been airbrushing this flat coat for decades and it has never failed me.
I saw the formula you use Thursday Matt @SSGToms , but then saw the Krylon thing last nite (Friday) and thought I’d try it, this is the first I’ve seen of your Fire truck, nice, and big!
I know, I know, that’s what she said rite
