Decals still get me…
Been modeling off and on for twenty-some years and decals still feel like a crapshoot. It’s usually silvering that’s the issue. Some like the Airfix 1/72 Spitfire MkI go on amazing, and then the Tamiya F-35 has issues.
Latest project: Italeri’s 1/72 F-117 Nighthawk. Black is Mr. Surfacer 1500 black. It went on very smooth with a satin shine. I elected not to apply a clear gloss.
Used Micro Set and Micro Sol. One mistake was I rolled the decals with a q-tip after applying Micro Sol, which I see is not recommended.
What’s going on here? The light parts match the paint color so I’m guessing those are good, but the darker sections are bubbles?
Stupid question, but do you apply a gloss surface for the decals? Gloss surfaces eliminate the air pockets that matte finishes trap, which cause silvering. Still have to use Micro Sol solutions.
:grinning_face: :canada:
I did not on this one, but frankly I have this issue no matter what undercoat I use.
Is there any way to save this?
I think Micro Sol (or another brand) makes a decal remover solution. Remove the offending decals, gloss coat, then, if possible, use better quality AM decals. Some kit brands include really crappy quality decals!
That looks like a very thick decal.
The ones offered on the Academy M113A1 Vietnam are horribly thick.
Yes. You need a sharp needle - not a sewing needle but a hypodermic needle. Poke the decal in several locations and touch a tiny bit of Micro-Sol to each location. You may have to do it several times. When one spot is fixed, moved on.
We do this on real aircraft with the vinyl graphics. Sometimes there are bubbles no matter how careful you are. We poke holes in the vinyl and smooth them out with a plastic straightedge.
Thanks, all. After poking around with them a little more, I decided to just strip them off and repaint.
We’ll try this again the proper way, gloss and all. Caracal decals on order now…
Hi
Always gloss, too risky otherwise! However, the curling over transfers is my pet hate! Should I add Fairy Liquid to stop this ?
I think I may have learned my lesson this time. Second coat of gloss is drying on the Nighthawk right now.
Hi, a gentle drying with a low heat hairdryer should assist.
Andrew T
Have read what the others say. Some good solutions around! :+1:
First of all you need to give the model a gloss finish over all. One layer is not enough, I do 2 or 3 layers. I use floor finish Bodenglänzer pure, you can also use something like Future or Pledge or what you find in your local DIY store or supermarket. Your model should look like this afterwards:
Let it dry for 1 or 2 days. Then apply the decals. Use softener under and on the decal. Your preferred softener will do the job. Next step is to seal the decals again with floor finish! It should look like this:
Let it all dry again for 1 or 2 days. Then apply the final matt clear coating and it should look like this:
Happy modelling!
Torsten
:small_airplane:
I think that last pic had a color shift but the point is clear.
All that sealing also means they won’t peel or flake off from age years later.
Don’t forget to dip the canopies in Future, or quick Shine, and let drip dry for a real crystal clear finish!
