That looks great! Kudos for getting the tape off without scratching the underlying paint. Did you clear coat between colors and new masks? I didn’t on my first attempt and it was like the masks/tape were glued on.
I didn’t use a clear coat I used tamiya paint except for the ak 3gen green and I let it dry for at least 24 hours between each coat for the masking tape I also used tamiya afterwards to remove the masking tape j I took off a corner gently with the tip of an xacto and then with small pliers remove the masking
I was careful to have the thinnest coat of paint possible
Stunning results! That digi - cam looks brilliant!
